Question about Garden
Replacing the self-propelled belt on my Murray mower
How do I replace the self-propelled belt on my Murray push mower model 22646X92A? I can't find an instruction manual anywhere!
  • 496 Answers
Here is the link to the parts list for your mower. Though it doesn't give instruction for replacement, it does show an exploded view of the components:
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-22646X92A-WALK-BEHIND-MOWER-(1999)-PARTS-LIST.pdf
I hope this helps...
Good luck
Posted on Aug 26, 2009
Self Propelled Gas Mower
with it off look under at blade probably bent and hitting frame replace blade if necessary
Aug 03, 2016 | Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
I need a replacment drive belt for murray quattro 40 briggs and stratton self propelled mower model 20615x51a
hi
please find web site for parts and id of your belt
http://www.partstree.com/parts/?lc=murray&mn=20615x51A+-+Walk-Behind+Mower+%282000%29
part number is ref number 28 in the diagram
& murray pt number 037x99
partstree site is good site
cheers paul
Aug 07, 2010 | Briggs & Stratton Garden
How to tight my drivimg belt in my push mower honda
The model shown 11A-034F200 is not a self propel mower. Now if you have a self propel mower, most of the time, the only way is either replace the belt or there may be a spring. I will not be able to tell you further without the proper model number.
Good Day.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Can't find a replacement belt for Scotts Self propelled
It should be a MURRAY part number 37X84 ( NOTE: that is read 37 "ex" 84 NOT 37 "by" 84, it is a part number not a measurement) but without knowing the exact model number of your lawnmower, I can't say for certain.
Sep 29, 2009 | Garden
Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Sep 11, 2009 | Poulan Pro " Pro" Self Propelled Mower
Self propel is out
Either the cable that engages it is broke or the belt that drives it is broke.
Jim
Jun 04, 2009 | Toro Lawn Mower With Toro Power Tools
SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Mar 13, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
1,067 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
