Question about Garden
Won't start my poulan wildthing is getting spark, gas and has 100 psi compression but won't start. the carb settings have never been touched until now, as I'm trying to figure this one out. any idea's???
  • hondajeff Jul 15, 2009
    thanks, i forgot to mention that i have drained the gas, put new (fresh) gas back in and also put a new plug in. it's got me puzzled. when I try to start it i get nothing, I pull the plug to check and it is wet with gas like it may be getting too much.
  • 245 Answers
I have the same model chainsaw, and sometimes it's very difficult to start. If you pull the plug and it's wet, with the plug still out pull the starter rope about ten times to clear out the excess gas. Dry the plug and put it back in and try to start it with the choke off. If it fires up, be ready to put the choke on if it starts. I forgot to mention that before starting you should pull in the trigger, push down the button on top of the handle, and hold it down while releasing the trigger. This sets the trigger so that it is on slightly. If it doesn't start, pull in the trigger and give it a few pulls that way. If it doesn't start, pull the plug again and see if it is wet. If it's dry, put the choke on and try to start it. If it still doesn't start, pull the plug, pour a few drops of gas in through the plug hole, replace the plug and try to start it with the choke on. If it still won't start, get a Stihl chainsaw.
Posted on Jul 30, 2009
    Sergeant:
  • 384 Answers
Drain the fuel and put in fresh gas. Change the spark plug. Prime and start as described in your start directions.
Posted on Jul 15, 2009
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
On this cart, I have cleaned out carb twice. Battery good. It runs shortly then dies out. Micro switchesx4 has been replaced. Spark plug good. Gas is good and getting to carb.
Determine if it is running out of fuel or no spark.
If it stalls but will run on carb spray or starting fluid
sprayed in carb opening then the fuel has problems.
If it will not run on the starting fluid then the spark is weak
or failing due to bad wiring or coils. Once you isolate
the problem to fuel or spark then you can probe those areas.
Be sure compression is good also. 100 psi at least.
Mar 09, 2015 | GAS Motorcycles
Won't start can't even get it to fire got spark getting gas ,don't know.
Check the compression! It has to be around 120 and no less then 100 to fire off. If it is ok, Have your carb checked out. It should fire off with some spray.
Feb 10, 2013 | Poulan Garden
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The spark plug is firing and is getting gas but won't start
It sounds like you have low compression in the engine. I would check the compression it should be 100 psi.
Mar 10, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
Weedeater will not start. was running, shut it off and then will not crank. I have checked all the obvious(spark plug and wire, has good fire, fuel filter and lines,took apart carb and cleaned good) still...
Pull the spark plug after pushing the primer bulb and cranking a few times...if the plug is "wet" (indicating fuel is present in the cylinder) then the next step will be checking the compression...compression should read above 90psi (preferrably 100-125psi)...if compression is below 90psi, the most likely culprit will be a stuck piston ring.
Sep 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Blower will not start, will not fire
Doubtful. Clean the bolts and re-mount but I doubt that'll fix your problem. Check spark with an in-line spark checker. Be sure you have the right oil/gas mix...or you will burn it up. How did you check compression, what is the reading? Anything less than 100 means the piston ring is stuck.
Aug 15, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Compression Poulan chainsaw
you can not set the compression on two cycle motors,the compression new is at about 90 to 95 pounds after six to nine pulls of the recoil
Jan 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
416 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
