Question about Kyocera Mita KM-2550 All-In-One Laser Printer
RAM error F020 when I try to print - Kyocera Mita KM-2550 All-In-One Laser Printer
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me...
E604 The image memory has a fault.
The RAM has a fault.
The expansion memory is not mounted properly.
E315 The image data coding mechanism has an error.
The coding chip has an error.
The image memory has an error.
If you have installed expansion memory I would turn off your Canon, uninstall the memory and turn on the Canon.
If the error is gone, try to print something.
If you are able to print without error then try re-installing the RAM and make sure it's in correctly.
Then see if the error is gone and try to print.
Sep 24, 2015 | Canon Office Equipment & Supplies
When printing multiple pages last few pages come out garbled
You may need to increase the amount of ram in your printer. Or turn it off then on, then try printing the large document. Do this before every print job, if it fixes your error, then you need more ram.
Mar 01, 2011 | Kyocera Mita FS 1010 Laser Printer
Hai, i want to ask for my F020, why my F020 always ask for simcard..?? if i take the battery,it's solve for a second (it wont error again), but sometimes it will error again.. what should i...
hi..
press 3,#,*,continously and press switch off /on button then switch ON it automatically format your phone and then the problem will be rectified..
then again it happened means check the hardware of your phone whether your phone sim insert lock is seated correctly or no chect it that....
good luck
If it's useful for you means plz rate me the 4 Thumbs ....
Jan 06, 2011 | Cell Phones
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
Error message 20
F020 Main or expanded memory error
1. refix the main board and try.....
2. replace the expanded memory of the printer ........and try.......
3. replace the main board.........
Oct 21, 2009 | Kyocera FS-2000D Laser Printer
Paper fed through the Multi-purpose tray exits from the rear of the machine rather than from the top.
There will be a setting in the printer. Most people have it set to exit straight through as they run card stock from multipurpose tray. Should also be setting in print dialogue box
Apr 24, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Ram error on a 6250 xerox printer
TRY FIRST (Solutions without parts):
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Apr 28, 2008 | Office Equipment & Supplies
Phaser 6250 "Ram error" (?)
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
Ram disk
Stangowner, In this case, the print job is too large for the available printer memory. Your choices are one of the following: Press to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the current print job. · Press Menu to open the Stored Print and delete the current job. To avoid this error in the future, do the following: · Reduce the number of print pages such as splitting the print data. · Increase free memory space by deleting unnecessary data in the RAM disk. As for the RAM disk: When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory. When you are ready to print the job, you must go to the printer and use the operator panel menus to identify which job in the memory you want to print. You can use this function to print a confidential job (Secure Print), or verify one copy before printing additional copies (Proof Print). NOTE: The printer holds the job until you delete it by using the operator panel or you turn off the printer. (This is the RAM disk) NOTE: Print and Hold functions require a minimum of 320 MB available printer memory. Also, you need to configure the RAM disk settings on either the OPERATOR PANEL OR THE PRINTER DRIVER. NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs. Take this link and print it out. It will help you later when you get "other" error messages. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html And here's a link for more "operational" situations. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section16.html#1087088 ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 3100cn Laser Printer
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
632 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
