Question about Fuji FinePix S1000FD Digital Camera
How do i reset the cam to factory specs - Fuji FinePix S1000FD Digital Camera
  • 390 Answers
Put the camera on P (Program Mode)
go to Menu --> Settings --->(Pg4) Restore Factory Defaults
Posted on Jul 25, 2009
My s9500 is stuck in night mode the dial turns but wont change how else can i factory reset
Posted on Jan 10, 2013
2009 Honda Accord EX-L 4 cyl Procedures to change exhaust cam shaft
You need a factory service manual
--at least for torque specs
Manual or not-- you can try You Tube Video
has to be there
Dec 02, 2014 | 2009 Honda Accord EX-L
I fouled up the timing on my 1990 Subaru Legacy Wagon. Tried resetting it to the factory specs but it still wont start.
You have not set it to the factory spec, and its probably 180 degrees off. Rotate the crank to top dead center (the mark on the crank toothed pulley, align the cam timing marks, refit the belt THEN release the tensioner. Rotate the engine manually to verify that all the timing marks realign themselves.
Jan 19, 2014 | 1990 Subaru Legacy
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
How do i adjust the valves on a 05 klx 125
I'm not 100% sure on this particular bike, but most late model hi-perf japanese bikes have shim adjustment. You can tell if you take the tappet cover off & the cams run straight ontop of the valves, If it's shims, you need to turn the motor until the cam lobes (pointy parts) face as opposite to the valves as possible (usually upwards) so the valve is completely shut, then use feeler gauges to me asure the gap between the valve tip & the cam. The valve springs can be compressed slightly (carefully) to let the shim on top (or underneath) the bucket be removed & replaced with the right thickness to give factory specs. Sometimes one shim from one valve can be used to make another valve correct, leaving less shims to buy. If not shims, should have a simple screw & locknut adjuster, same setup, just measure between valve & rocker, adjust to factory specs (or slightly smaller for more go)
Dec 24, 2009 | 2005 kawasaki KLX 125
1998 4cyl.camry had a stuck valae due to bad gas{varnish}. removed valve cover, got valve unstuck. had to remove exhaust cam, but not the intake cam. need to reinstall and time exhaust cam. can not...
simple to figure that out . the key ways are always up on camshafts. it allows for them not to fall out when assembling the engine . so use the balancer to determine tdc (top dead center on cyl one) and make sure both keys are straight up . (just loosen the cam retainer nuts and look to see what set of marks they line up with and dont forget t re-torque them to factory specs somewhere between 22 and 28 ft lbs but not a lot more) , google the specs up to be sure
Oct 29, 2009 | 1998 Toyota Camry
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Need to reset unit to factory specs
Called up the AVmap site online and the answer was right on their website.
May 01, 2009 | GPS
How to reset to factory specs??
Enter the SETUP menu and select RESET. You'll be prompted to reset two sections. Answer YES to both and everything that can be set to default will go back to the factory default state.
Jan 13, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
728 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
