Question about Cell Phones
I have an LG Verizon Voyager VX10KV11. I had it charging overnight and when I looked at it this morning I noticed that the Charge Complete screen was burnt into the front external screen. Is there a way to fix or refresh the screen or will I need to talk to Verizon?
LG Voyager Locked
To enter unlock code for LG, You need to insert sim card from network which is ... You can get Your LG VX10000 Voyager IMEI number by typing *#06# or after ... are locking devices on carriers demand, so when you unlock LG VX10000 ... sim-unlock.net/simlock/LG/VX10000 Voyager/ sim-unlock.net/simlock/LG/VX10000%20Voyager/
hope this helps
Feb 08, 2012 | LG VOYAGER VX10000 Cellular Phone
Voyager phone external screen is blank. When powering up Verizon logo comes on and then it goes blank
Need more info...
Can you see the power and antenna strength bars before it blacks out?
Leave it to charge for at least a half hour before trying it again.
Leave it on the charger while you're trying. Try another charger/outlet.
Remove the battery for a minute or three and then put it back together and try again.
Further suggestions would depend on results and any other symptoms.
Dec 18, 2010 | LG VOYAGER VX10000 Cellular Phone
My lg voyager has lines comin up from the bottom
if the outside screen is not cracked and its just the internal lcd take it into a Verizon store and they should swap it out under warranty, otherwise if they will not do it send to LG and they will replace. Don't tell them you dropped it at the Verizon store tell them it was in your pocket and something must have pushed against it
Jul 11, 2010 | LG VOYAGER VX10000 Cellular Phone
Switching back to verizon from metro with same phone
all you need is lg downloader or lgnpst software you can google those and a verizon prl. and once you have either of those softwares and the drivers for your phone is installed u can get that from here:http://www.humpa.com/vzw/. and a usb cable for your phone to connect it to your computer and where it says prl/eri u can load the verizon prl and write it to your phone. you will find it in the link i have given. dont look under the part for lg voyager but instead look under the section for LG-VX8500 Chocolate PRL - PRL.
  • LG-VX8500 Chocolate ERI - ERI.bin zip - You should only need this if you screwed up! hopefully this helps. good luck
  • Jul 08, 2009 | LG VOYAGER VX10000 Cellular Phone
    Wont charge, dead battery
    make sure that your charger is not bent, i had the samd roblem sometimes you just have to get a new charger or just get that one to position right so that it will charge the phone
    Apr 05, 2009 | LG VOYAGER VX10000 Cellular Phone
    LG Voyager won't reboot
    Interesting, normally the screen only appears with water damage, which I am sure Verizons customer service has continued to tell you that is the cause without thinking the customer might not know for themselves, The only way to fix this is to got to a Verizon Wireless store and ask them to do what is called a software flash, now it may delete all your information on your device but at least it will work, if you need any more help with this let me know.
    Jan 02, 2009 | LG VOYAGER VX10000 Cellular Phone
    Can i retreive erased text messages from a lg voyager vx9900
    Um The Voyager Is Not A vx9900 It Is Called A vx10000 The vx9900 Is The Lg EnV. But As Far As I Know You Cannot Retrieve Txt Messages With Almost All Verizon Phones, But Im Sure You Can Get A Record Of Txts From A Certain Date If You Ask Verizon, They Might Hit You WIth Some Crazy Charge Tho.
    Tim2o9
    Dec 31, 2008 | LG enV VX9900 Cellular Phone
    Cell Phones Logo
    636 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
