Question about NAD Audio Players & Recorders
NAD 5425 CD with dead backlight: ONE big bulb not 2
I read robotek's answer to the problem with the NAD 5425 dead backlight.
Unfortunately when I open my unit, there is one big bulb (20mm long)
soldered to the PC board. I'm in the USA, and trying to find a replacement bulb.
Any advice?
Nope
Posted on Jul 15, 2009
Display screen on 501 no longer working
Needs 2 new bulbs. Very common on older NAD players.
If you look very closely you'll see the display is infact working
but just not lighting up hence the need for new bulbs.
Jun 14, 2011 | NAD Audio Players & Recorders
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Jan 04, 2010 | NAD C521 CD Player
NAD CD 5425 - No Spin - Sometimes
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Dec 23, 2008 | NAD C521 CD Player
NAD 5100 monitor wont eject
Hi ntravers9
You could fix this yourself, in saying this of course, you will need to also source a new belt for the player ( I can help you there too) That is probably what is preventing the Cd tray from opening. If you where to remove the lid, and give the transport a little assistance in the direction that things initially start moving, then you can be sure that the mechanism is not damaged in any way, and that a lazy belt is the source of you problem.
Do this if you are into fixing it yourself, to see for sure what is happening and we can go from there.
regards
robotek.
Dec 17, 2008 | NAD C521 CD Player
NAD 5425 CD Player display light out
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
Dec 11, 2008 | NAD Audio Players & Recorders
Light doesnt work
hi...
Do you mean the Display?
If so ,it's a backlight issue. Some use little bulbs ( NAD and Yamaha)
Take it to a tech ( Ask your stereo store)
Oct 14, 2008 | Marantz CDR631 CD Recorder
Nad c520 high pitched ringing
Hi, From your description, it sounds as if the noise is coming from the circuit that controls the display backlight. If I recall correctly, the C520 has an EL backlight just like the C521 (which I have one of). On the front of the circuit board, there should be a little yellow trimmer potentiometer that controls the brightness of the display. It may be that the noise will go away if the brightness is turned down some. If  the noise varies as you turn the controller, but doesn't go away completely, the backlight may need servicing.
Aug 06, 2008 | NAD C521 CD Player
NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Sep 06, 2007 | Audio Players & Recorders
NAD 712 Stereo Receiver display
http://www.bulbdirect.com/ who's your mommy? ;]
Feb 01, 2006 | NAD 712
the lamps i use on all NAD displays(and have done since the early 1990's) last heaps longer.You can get them from RS components in your country. They are a 14v 37ma type, and seem to last. Never had any come back for replacement again. P/N 351-9585. Increasing the ballast resistor where fitted by 25% in valua also helps preserve them
Jan 29, 2006 | NAD 712
562 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
