Question about HP LaserJet 2840 Printer
Was trying to send a fax - now it says Error 70 turn off and back on - have done this 5 times.
It can be a defective fax module or formatter, but most likely, it is a software issue.
Make sure you have the latest firmware.
When/if firmware is the latest version and problem persists, go to Menu -> Service -> Restore Defaults.
If problem persists, it might be a good idea to try a different land line, if you have one available, before purchasing new hardware.
Please note you need a different board depending on which region of the world you live in. I'm assuming North America here.
The fax module for the 2840, is about $27.31.
Part information:
Q3977-60011 - PC Board (Interface) : Line interface unit (LIU) PC board - Telephone interface board for the printer.
If the problem is in the formatter (main board), the price goes up to $405.65. Please not, that the LIU (fax module) is included in this.
Part information:
Q3948-69006 - Formatter / LIU assembly (for North America) - Includes the formatter PC board, the line interface unit (LIU) PC board, and the metal card cage.
Posted on Jul 23, 2009
Error 350 - how do I fix this?
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
However under rare conditions incompatibility between the two machines may cause the remote machine to simply get this code.
Try these steps...
1. Press setup, and then go to TOOLS.
2. Press okay on TOOLS, then look for RUN FAX TEST. Then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, and then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Also you can try to reset the printer.
1. Take out the cartridges from the unit .
2. Make sure the unit is connected to the wall jack directly without any surge protector.
3. Unplug the power cord from the back of the unit ( without turning off the unit ) .
4. Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5. Do not release the keys after a few seconds you will find the hp logo or bars moving across the screen .wait while the unit turns off.
6. After one minute turn on the printer . It will go into alignment phase > let it finish .
7. After its done > try to make a copy .
Note - you can also try the OK and CANCEL key combination in place of # and 6
Jul 18, 2011 | HP Officejet 6500 Wireless All-in-One...
Fax does try and send but then stops and prints an error page err 388 each time?
The remote fax machine might be defective.
Solutions
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Jan 05, 2011 | HP Officejet 6500 Wireless All-in-One...
Recieve error 334 when sending fax but i am able to recieve faxes
Error Codes: 332, 333, 334, 335, 336, 337, 338 ECM, 339 ECM, 340 ECM, 341 ECM, 342 ECM, 343 Definition
Solutions
Error Code: 334
Definition
Solutions
Sep 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Canon mf4150 -- fax has a mind of its own?
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Can send faxes but cannot receive - shuts off after 2 rings
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
MFC-8220
Its the CIS unit. Part number LE7949001. $70 retail price.
Aug 15, 2008 | Brother MFC-8220 Fax
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
HP LaserJet 2840 Printer Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
