Question about Samsung CLP 300 Laser Printer
Red light is on. printer wont print
Tried the command net stop spooler idea - but it didn't work.
Have had the problem for a couple of months now - it used to fix itself if I tood the toner unit out and put it back in.
None of the toner lights have been on - just the status light.
Help!
  • 30 Answers
Perhaps the Waste toner bottle on the left side of the drum unit is full or the sensors are dirty.
Posted on Sep 21, 2009
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
Printer is not working. There is no error light on and the ready symbol light is on. Nothing willnot print
Have you checked if there are any Documents Stuck in Queue to print ? ( under Control panel - Printer and faxes folder )
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone. ( Refresh the Printers and Faxes folder )
If this does not fix the issue :
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 03, 2010 | HP LaserJet P2015dn Printer
Print jobs stuck in cue
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jun 25, 2010 | HP LaserJet 8500 Color Printer
How do I cancel an order to make it stop printing and clear it out of the system
Click on Run
Alternate method,
Click STart
Click RUN
Type
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jun 23, 2010 | Zebra 105SL Thermal Label Printer
Printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Apr 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
Red light on and i can't print
Open command prompt and then type command "net stop spooler" and then type "net start spooler" followed by restarting your printer.
Jul 13, 2009 | Samsung CLP 300 Laser Printer
Can't delete print job for an Epson C** printer
I don't know which OS you have. I will assume it is a newer OS like WinXP. You have tried to reboot the PC I'd imagine. Try stopping the print spooler by running the following command from the cmd prompt.
net stop spooler
Then check the print queue and see if you can manually delete the print job. Then issue the command
net start spooler
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
Not printing but fax works
  1. Click Start, click Run, type command, and then click OK to display the command.com window.
  2. Type net stop spooler, then press <Enter>.
  3. Type sc config spooler depend= RPCSS start= Auto, then press <Enter>. The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
  4. Type net start spooler,then press <Enter>.
Njoy
Apr 12, 2008 | HP PSC 2410 All-In-One InkJet Printer
Both power & feed lights flash
Information gathered: Basically the printer carrier has stalled.
Lexmark documentation states that you should turn off your printer and wait a few seconds and turn the printer back on.
Restarting the spooler will sometimes do the trick as well.
Go to start, run
type: <cmd> without <>
Command prompt will open up.
Type: net stop spooler
The spooler will say it stopped successfully.
The spooler will say it started successfully.
Hope this helps!
Jan 20, 2008 | Lexmark JetPrinter Z22 Color InkJet
Samsung CLP 300 Laser Printer Logo
318 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
