Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Liquid leaked into tv
My 2 yr old was 'helping' me to clean, and drowned the 46" LCD screen in WIndex. Some must have gotten between screen & housing, because now the lower 1/5 of the screen has a water-pattern stain across it. Like some capillary action drew the windex up into the screen. I've got strips of paper towel stuck in there to try to draw some up, but other than that i'm not sure of my options (other than beelining over to an adoption website). After the stuff dries, is there likely to be permanent damage to the LCD?
  • nivee Feb 08, 2009
    I was cleaning my LCD tv screen with a Professor Amos cleaning product called THE BOM. Instructions said to 'spray directly onto surface' and wipe with a microfibre cloth. Which I did. I know realize that I should have sprayed the cleaner onto a cloth first. After cleaning I noticed a cloudy finish on the screen and now the viewing is a bit blurred. Have I damaged the TV? Or is there a chance it will be okay once completely dry?
  • 211 Answers
Hi Tracy,
I have the sweetest grandchildren and tey are always willing to help also, so we have to love the children for all their wonderful help. ( NOT !!! ) But lets not send your son to the adoption web sight just yet. I'll start by letting you know ( in a sigh of releif for you ) that your tv is not damaged forever, although, when the windex drys, you will probably see a dirt stain on the screen, since the windex probably did it's job and cleaned the dirt off, unfortunatly the residue is between the screens. You have 2 layer of plastic screens for your TV. One is a lexan shield and the other is a riffled substance plastic. To seperate the two of them, you need to take the front of the TV off, normally by removing screws from the inside of the TV ( this can be a tricky job and I really suggest you have a pro do it if you haven't worked on TV's in the past ). If you do it, be extra careful not to break the screen or sheild after removing as they can get a bit pricey. When you take them out, they will seperate ( one lays on top of the other, no real trick to them ) and then just grab your windex ( the remains of the bottle that your son left you ) and clean them like you would glass. Of course after you clean the screens, replace them in the oppisite proceedure of taking them apart and wella, all is ok again and junior remians a loving and helpful son. smiling. I hope this helped. Nice day.
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
LCD or computer screen dirty?
The best way to clean it up is with a microfiber cloth VERY lightly moist with warm water. No soap. No solvents. No alcohol of any type. NO WINDEX. NO 409 or any household cleaner. Be sure that if you're cleaning an LCD screen that you apply VERY little pressure, otherwise you can damage the screen.
For an old-fashion CRT screen (NOT A FLAT SCREEN LCD), you can use the same as above or you can use a small amount of water + rubbing alcohol. Be sure that the liquid doesn't drip INSIDE the monitor.
on Mar 26, 2010 | Computers & Internet
Liquid got between frame and screen how do i get it out
need to dis assembly the frame of the tv and take the 3 screens out and cleaned may sure you put this back in the same way you took it o each side is different do not use any cleaner like windex
Dec 18, 2010 | Mitsubishi WD-60735 Projection Television
Have a 2 yr old 46" Sony LCD. No picture at start up.
It may just need time to warm up. Try starting it up and waiting around for the picture to show.
Jun 04, 2010 | Sony BRAVIA KDL-46WL140 46 in. LCD TV
2 yr old spayed approx 60ml of windex over the
The windex may have seeped up into the screen. It should dry in a few weeks.
Oct 03, 2009 | Joy Toshiba M105 S3002 Notebook
I would recomend 1 part white vinager to a 4 part water mix and a clean micro fiber cloth! NEVER USE WINDEX or like product on the screen as it may be damaged!!
Please rate my response!
Jan 27, 2009 | Sanyo DP32746 32 in. LCD Television
Cleaning samsung big screen television
sorry for the cut off chat. this website crashed my computer.
enough said,
the manual is here.
There are instructions on how to open the TV.
Aug 24, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
"clouds" on 32" Samsung tv screen
My best suggestion is to replace the inverter to the lcd panel.I could look up the part number if you need.Let me know - edcarson
Feb 18, 2008 | Samsung TXM3281HF 32" TV
Water damage
take the front screen off inspect it, wipe down the tubes and mirror with paper towels and a glass cleaner dont overspray. try that. good luck
Aug 15, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
259 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
