Question about Whirlpool ET8CHEXSQ Dryer
Whirlpool Dryer We have a whirlpool dryer that we bought a few years ago. We can't even find the model # on it. The problem is we are getting brown marks on our light clothing. There is a felt strip on the back panel where we believe it's coming from because when you wipe it with a rag, brown comes off on it. Do you know what we can do to prevent this problem?
  • 373 Answers
The marks are coming from your dryer seal. I had the brown mark problem on my Whirlpool LER4634EQ1 Dryer. It turns out that the inner drum seal wore the paint off the pilot diameter on the inner wall. The pilot diameter rusted and the rust transfered onto the seal. The marks on the clothes are rust marks. I replaced the seal on my dryer, but don't know how long it will last. You may need to try and paint the pilot diameter. The seal with glue was $34 delivered from pcappliancerepair.com. Here's pictures of the rust: http://s2.photobucket.com/albums/y48/ZeeVert/Whirlpool%20Dryer/
Posted on Jun 11, 2010
If you believe the felt is the problem, you can go to Sears.com and look up the replacement part via the Parts Direct section. You will need the Model number which if you open the door, it should be a label on the body of the door frame. Using the model number you can look up the parts diagram for your Dryer. Hope this helps a little.
Posted on Jul 15, 2009
I have a Whirlpool electric dryer, model #LER5636EQ3. Several years ago, we replaced a part due ti the dryer not heating. It worked great, well a few years ago, the dryer began taking 2 cycles to get the...
BY THE TIME YOU PUT MORE MONEY IN IT, HAVE YOU PUT TO MUCH IN IT ALL READY.. YOU CAN CALL WHIRLPOOL FOR IDEAS OR THERE SERVICE TECH FOR APOINTMENT. NO MATTER WHAT IT WILL COST. WEIGHT YOUR OPTIONS GOOD LUCK
Jun 23, 2017 | Dryers
How do you change a dryer belt
That is the same model dryer I bought for my parents eight years ago. You will have to contact Whirlpool for a repair guide.
Apr 22, 2012 | Estate TEDS840JQ Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer will not start. The light comes-on, but no go. Reset circuit breaker in garage, cleaned-out lint trap. Door switch appears fine (I replaced it a few months ago). It's a Whirlpool...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 05, 2010 | Whirlpool LER7646E Dryer
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
Brown streaks of clothing from dryer
Check your front and rear felt seals. How old is the dryer and what is the model number?
Eric
May 16, 2009 | Whirlpool LER4634J Electric Dryer
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool ET8CHEXSQ Dryer Logo
162 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
