Question about Wave Audio CS801 Speaker
HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
MY SUBWOOFER IS INFINITY AND MY RECIEVER IS SONY
BUT SUBWOOFER HAS CONECTTION LIKE SPEAKER HIGHT INPUT AND LOW INPUT AND RECEIVER DO NOT HAVE THAT CONECTION
    Problem Solver:
  • 5 Answers
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Posted on May 18, 2010
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
I have a s108sp subwoofer with a right and left input assuming this is for a cable going to one input on my Sony reciever. The subwoofer also has inputs for speakers. Do I plug the speaker wires into...
Hey there houleo!
If your subwoofer has a stereo input and stereo outputs, then it's a good idea to send the signal from your receiver to the sub, then out to the other speakers you have hooked up. Some subwoofers will take the low frequencies out of the signal to the left and right speakers, so that the sub handles it alone. This often gives a nice crisp sound.
Reciever/amplifier
l l l l V V Subwoofer l l l L------> Right speaker
V Left speaker
If this helps you out, I'd appreciate if you rated me well :) If you've got any more questions, feel free to ask! Cheers! -The Chicken
May 26, 2011 | Acoustic Research S108PS Subwoofer
How do I hook it up to my Surround sound reciever?
Hooking up a subwoofer is dependent upon what hookups are availble on the receiver and subwoofer. Does your receiver have a specific subwoofer output? If so, is it set of speaker-wire terminals, or is it an RCA jack? The Wharfedale can accomodate either one of these as an input. There are four speaker posts on the back of the subwoofer, and there is a single RCA jack input.
May 16, 2010 | Wharfedale Topaz SW-10 Subwoofer
Sony SW no sound
does this sub have an LFE output? if so, connect that to the LFE input on the reciever and make sure it is set up properly in the set up menu in speaker configuration. if the sub has speaker line input outputs, connect speakers to input of sub and out of sub to amp/recvr
May 10, 2010 | Sony SA-WM40 Subwoofer
I need the wires to conect my infinity basslink 10''
Any auto parts store or WalMart will sell adequate speaker wires. For a sub of this power rating, you'll be fine with 14GA speaker wires (pronounced 14 gauge) but if you want to get beefier wires in case you upgrade the sub later, I'd recommend this 10GA hookup kit or something comparable.
Feb 13, 2010 | Car Audio & Video
Voltage on subwoofers input
Is the subwoofer a self-powered unit? If yes, it would have a minimal voltage showing on a meter. If the input is a line input, it would not have a problem taking in a line output (not speaker - never!) from your receiver. If the only output you have from your reciever is a speaker out, then purchase an L-Pad type speaker to line matching transformer. You can also take one of the input channels coming from the source and Y out a side to the sub pre receiver, but you then you would need to be able to adjust levels on the subwoofer independently from the receiver.
Jul 24, 2009 | Audio Players & Recorders
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
76 people viewed this question
Top Wave Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Wave Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
