Question about Konica Minolta magicolor 2400 Laser Printer
Error light flashing when we restart no paper jam or obvious problem
  • 210 Answers
Start the Konica Minolta Status application from your computer, it will give you more info.
Posted on Sep 03, 2009
pagebor
  • 2785 Answers
SOURCE: Orange Flashing Light
plz try by reinstalling the drivers and report back
Posted on May 31, 2008
SOURCE: paper jam
pick up roller are not going down to pick up the paper
i have try on empy tray as well allso give error 241.10
Posted on Oct 23, 2008
  • 9 Answers
SOURCE: my brother laser printer HL-5050's
Hi
I've nearly the same problem....My printer(HL5050)  takes only a little bit of the sheet, then paper led flashes.
I've found a block into the paper feeder. This printer is impossible to disassemble.!!...even if I've the service manual, because for taking away a simple pressed paper block , it's necessary disassembling  almost all the machine!!! No comment
So I'd an idea:
I've sprayed into the paper feeder a great quantity of a cleaning spray (without oil) , in order to get the paper block wet, then , by means a school-book plastic cover, used like a paper sheet,  and  manually acting on the gear, I've pulled this plastic sheet up and down several time (spraying in the same time)in order to  remove these hard paper blocks. Now my feeder seems free. Tomorrow I'll try to test it.....
Regards
PS To do this it's necessary the only removal of left cover, in order to reach the gear which allows the paper to advance manually.
  • 29 Answers
SOURCE: flashing E3 error code for a paper jam
I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
Posted on Mar 15, 2009
SOURCE: lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
Posted on May 21, 2009
Printer will not print in black was the first problem and now after less than a minute after turning on it has the light for 'on' flashing green and amber constantly
Try this:
1- Pull the cartridges out, restart printer then reinstall the cartridges again
2- The blinking can mean any of these: paper out, paper jam, cover open, printing error. Please check that there is enough paper, no paper jam (sometimes even the smallest piece of paper will cause that error, then restart both (the printer and the computer)
Best of luck
Jun 12, 2010 | Canon BJC S300 InkJet Printer
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
All lights on Dell 1710 printer panel simultaneously flashing.
do you or have you recently started using recycled paper. I know for a fact that recycled paper and Dell printers dont get along very well. It's the dust and it will block the hole for the sensor which could show an error or make the printer think there is a paper jam. Youneed a can of compressed air and thoroughly clean it out. If that does not work you can remove completely the software from the pc, let the pc reboot and reload the drivers and software. good luck
Sep 21, 2009 | Dell 1710n Laser Printer
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
Sep 18, 2008 | HP DeskJet F380 All-In-One Printer
May 31, 2008 | Office Equipment & Supplies
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Konica Minolta magicolor 2400 Laser Printer Logo
73 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
