Question about HP Pavilion dv6000z Notebook
My comp shut off and wont turn on anymore.. lightening bolt comes
I have an HP Pavilion dv1000... I know it's older, but worked like a charm, until last weekend I was on it and all of a sudden it went *poof* and turned off.. now it wont go back on. There's a little lightening bolt at the front of the computer that lights up, but that's it. I checked the power cord and it's fine... please help! :(
  • kimberlya303 Jul 15, 2009
    Thank you!
    I tried and it was not successful :( I'm wondering if it could mean I need a new battery!? Or could it mean the power source blew!? I'm also concerned because I was told that if I take the hard drive out I could lose everything if it's under 'my documents' and such, because it only works for THAT computer, is this correct??
    Scholar:
  • 105 Answers
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Posted on Jul 15, 2009
I have hp pavilion dv1000 computer. i was using skype v3 for two years with no problem. then i installed skype v5.3. Since then my microphone doesn't work. It looks like some setting got changed. I...
I think you are right.
Try changing your audio-settings, until your mic works again.
I've you still need help, i can remotely control your computer to fix this problem
Good luck,
DJ Skywalker
Jun 19, 2011 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000 fan not working
Try to clean your fan with anti rust oil, maybe due to old age the mechanism inside your fan is already clogged.
http://podnutz-hdlaptoprepairvideos.blogspot.com/
May 26, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a hp pavilion dv1000 laptop and it randomly hibernates
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
Nov 26, 2009 | HP Pavilion dv1000 Notebook
I hear one single beep coming from computer and number lock and caps lock are blinking .. is this an issue with the mother board?
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Nov 22, 2009 | HP Pavilion dv1000 Notebook
Locked out of my hp pavilion dv1000
this paassword is for bios u have to reset it.
open the back side of laptop then u see cmos cell on chip.
remove it for 1 5minutes then again fix it then stsrt now it not ned any password.
Jan 29, 2009 | HP Pavilion dv1000 Notebook
Problem with drives
Hi Elton, Since so many are having problems looking for the drivers, I'm going to try and up load them someplace. Give me a few days to set that up.
Sep 07, 2008 | HP Pavilion dv1000 Notebook
Pullin my hair out
  1. remove power
  2. remove battery
  3. remove memory modules
  4. reseat memory
  5. replace battery
  6. plug back in.
May 21, 2008 | HP Pavilion dv1000 Notebook
DV1000 Shut Off For The 4th Time
1.when this situation occurs remove the battery and insert after 1min.
2.now start again
3.if it does not start now again remove the battery and also RAM after 5min insert both again
Feb 17, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion DV2036e Wont Boot
how long it stays on???let me know
Dec 17, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z Notebook Logo
210 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
