Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
Gu1100xtl1 won't drain
Everything seems to run smoothly but, at the end, the water just sits in the bottom and pours out when you open the door
  • 6,784 Answers
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jul 15, 2009
Why is my Viking refrigerator/bottom freezer leaking water out bottom of door? There is a layer of ice on bottom of freezer.
The ice on the bottom of the freezer is blocking a drain hole. When the freezer defrosts automatically, water drains out the bottom into a tray, where it evaporates away and you never see it under most conditions.
The solution is to either defrost the freezer manually and let the ice melt, or pour some hot water into the bottom of the freezer to thaw out the ice and clear the blockage.
If the drain is plugged because of some foreign matter, either method will make a mess, so have some towels at the ready to sop everything up if need be. If it is blocked, a can of Air Duster (like for cleaning electronics) might be able to blow the blockage out, if you seal the nozzle tube up as it is stuck into the drain.
Most likely it is just ice blockage.
You can access the drain tray (where the water goes to evaporate) by removing the grille on the front bottom of the fridge and peeking / poking around. You might want to keep an eye on it as you defrost the freezer or pour hot water in the bottom - it can over-fill quickly.
Jul 20, 2014 | Viking Refrigerators
How to clear out the drain tube on a kitcheaid refrigerator
Freezer has been leaking water at the bottom. I opened the drawer/door and removed the bins, there was a small amount of ice formed on the bottom at the back, I broke it away and poured a small bit of warm water in the black drain hole. the next day the bottom and rear are full of frozen ice and it is difficult to open the drawer/door to the freezer. Everything is covered with frost. Help!
Jun 18, 2014 | KitchenAid KBFA25ER Bottom Freezer French...
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Csx22br freezer ice build up water runs out bottom of freezer
Your defrost drain hole may be plugged or frozen over. Open the freezer door and remove the lower shelf and basket so you can get to the back evaporator cover, and right under it is the drain hole. Remove what ice may be built up and pour very hot water into drain. It helps to have a syringe to remove the water and pour more hot water into drain. Then use a wire or other flexible tubing to poke into drain to clear restriction then flush with water.
Oct 30, 2011 | Hotpoint Refrigerators
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
GE tfx22r leaks water out bottom of freezer door. Bottom of freezer covered with ice. Vacuumed and cleaned evaporator and coils. ice maker water is shutoff. Water seems to be coming out from behind crisper...
defrost drain is clogged, remove back panel, and pour hot water down drain and blow it out with pressure of some sort until water passes freely
Nov 01, 2009 | Refrigerators
Water leaking from door: top left door of my french door fridge (with freezer on bottom)--water leaking from the very bottom right corner of that left side door
your drain is clogged. if ice isbuilt up in the freezeer floor. when the freezer defrosts and the drain is clogged it has no where else to go other than ouot the front. pull everything out of the freezer and check twards the rear at the bottom. remove as much ice as possibile let set unplugged and door open for 3 hours. then take a cup of boiling water and pour it back there. if it dont drain repeat that process with the water-have a towel ready because if the water stays back there long enough it will get cold. you need to keep the water HOT. ice could be built up in the drain. hope this helps
Oct 28, 2009 | Refrigerators
Freezer door leaking alot of water on floor no ice on door
This really sounds like a plugged drain. When the unit goes into defrost the water should run down the drain into the drain pan...when the drain is plugged it will run over and down to the bottom of the freezer thus leaking out the bottom of the door and onto the floor. You will need to take everything out of the freezer and remove the screws that hold the back panel on break out the ice at the bottom and use hot water to pour down the drain to clear it.....also if you have a small hose to shove down the drain that will help out alot.
Oct 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Drain in the freezer keeps freezing up and causes water to freeze up in the bottom of the freezer
If this is anything but a GE fridge then you can take a regular electrical wire and strip it of the plastic shielding. Next twist one end around the heater that runs under the evaporator above the drain hole. Make sure you have enough wire to extend it about 1-2in into the drain hole.
Now when it goes through a defrost cycle the heat traveling down the wire will keep the hole defrosted.
Nov 05, 2008 | Refrigerators
Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
236 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
