Question about Cell Phones
No access to mass storage of the phone and not suficient charge
USB port not recognized by my computer,no access to mass storage of the phone.
no charge(message warning bad contact charger)
same answer with power charger or battery charger)
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
HOW DO I TRANSFER PICTURES FROM MY MOTOROLA WX345 PHONE TO MY COMPUTER
plug USB cables into phone & PC, open the phone and see "USB config"
'Mass Storage' or 'Com port'. highlight 'Mass Storage' and 'OK', PC will recognize the phone as removeable drive 'x' usually 'e'. there will be different folders for music, photos, etc, use the removeable drive like any other drive to xfer files between the phone and the PC.......
Jan 09, 2012 | Cell Phones
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say " usb mode. connecting to mass storage" then that will go away after a few seconds and then it...
The "USB mode" and "Connecting to Mass Storage" message will get displayed when the Camera is connected to the Computer and is recognized by the Computer as a Mass Storage device. This is not an error message and is a normal operation.
You can change the Mass Storage settings in the Camera (depends on the model) The USB Select or USB Connect option in the Camera can be changed to PTP, Mass Storage or PictBridge mode. Set the option in the Camera to PTP and connect it to the Computer and check if the Computer is recognizing the connection. Once the computer is recognized, it appear as a removable Drive.
You can transfer the images from the Camera to the Computer from the Removable Drive by copying and pasting.
Thanks for contacting FixYa.
Apr 07, 2011 | Sony Cameras
Cannot reconize t10
On a memory card using the computer
To access files on a memory card using the computer, perform the following steps:
1. At the main, screen tap Menu.
2. Tap Settings.
3. Tap Phone settings.
4. Tap USB settings.
5. Tap Mass storage.
NOTE: You will see a blue circle in the radio button next to the selected item.
6. Tap Save.
7. Press the red End key to exit to the main screen.
NOTE: If you do not exit to the main screen, you will see the message UMS only available in idle mode when you connect the phone to the computer.
NOTE: The phone must be unlocked for the computer to recognize the memory card.
8. Plug the USB cable into your computer's USB port.
9. Plug the other end of the USB cable into the charging/headset port on your phone. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
Hello, I just received my mini KA08 yesterday, I can not get either battery to charge. the wall plug that comes with it only stays red. the computer usb will not even recognize the phone...
Red means that is charging, green means that is fully charge. When you connect the phone to the computer and it doesn't recognize the device as Mass Storage Device, then just restart the computer, it should come up with two device recognized, one for the memory card and the other one for the phone. Some phones require that you choose which function to use while you connect to the computer, just tap Mass Storage.
Oct 15, 2009 | Cell Phones
Failed to connect
You need to change usb connection to USB mass storage from your phone. Then it will be ok try it .
Sep 10, 2009 | LG KF600 3MP InteractPad Triband Phone...
Cant get usb data cable to work
As long as you have a memory card installed in your phone, you should have no problem. Use a micro SD card of no larger than 4 GB. Attach the cable to your phone and computer via an available usb port. Your pc will then recognize your memory card as a mass storage device, and you cn drag and drop your files to and from the computer.Make sure your phone usb connection is set to mass storage.
Aug 06, 2009 | LG Vu CU920 Cellular Phone
Computer doesn't recognize CECT P168C as mass storage or webcam.
i) when u connect mobile to ur computer u'll get 2 options i) mass storage  ii) webcam , try to select any one of them
Jan 18, 2009 | Dual Electronics CECT P168 Cellular Phone
"little tikes- my real camera" can't upload pics
The USB connection seams to be very sensitive try pushing the USB cable into the camera firmly and wiggling it. Once the mass storage device is recognized be careful not to move the plug. The connection can be very flaky.
Good luck,
Mike
Dec 10, 2008 | Little Tikes My Real Digital Camera Pink
About Sigmatel S3
once u have connected USB from mobile to system... u get a message option of mass storage and com port.... better select mass storage for easy process... wen u select mass storage automatically the memory card will be displayed on my computer ( same a pen drive)..... NOTE: this process does not shoe phone memory..... only u can access memory card.... thank you... VINAY
Aug 26, 2008 | Handmark Software MobileLists (950142) for...
Cell Phones Logo
90 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
