Question about Samsung HL-P5063W 50" Rear Projection HDTV
I believe the bulb is out, I turned it on and the picture did not come on, has power. Suggestions?
  • 304 Answers
Look in the rear of the set and locate the Lamp Door, Remove the screws. Once you have removed the Lamp Door you will see a Lamp Module. There are two screws to remove on each side ot the Module. Remove the Lamp Module by the handle and look at the front glass, DO NOT TOUCH at all. If you see shattered glass inside then the Lamp is bad and needs to be replaced. Advice: Since your set is a older model it is advised you replace the Lamp Ballast as well because if you replace only the lamp,the Ballast might reverse damage your new lamp. Lamp part# is BP96-00826a and Ballast is BP96-00690A. If this does not fix the problem then come back and report what you have done and what the symptoms are. Togather we Can get this tv fixed.
Posted on Jul 16, 2009
Right front side turn signal does not work replaced all bulbs and checked fuses headlight flashers work when hazards are on front to back except driverside turn signal ,in dash right stays solid left
I don't believe it would be a bad ground for just one light. It could be a wire, a socket connector, or the bulb socket itself. See if the wire has power at the socket when signaling left, with key on. If there is power, probably a bad socket or connector. If no power, check for power coming from flasher-the wire going to front left, or driver's side. If you have power from the flasher, but nothing at the socket, the wire has probably broken.
Good luck.
Feb 06, 2013 | Cars & Trucks
My Samsung HL-85679W DLP LCD TV has sound but no picture
Look to see if there is a little green light on the bottom of your case, this would indicate the bulb is working, if the light is red, you need to replace the bulb....good luck
Feb 07, 2010 | Televison & Video
Buzzing sound from under dash when engaging turn signal for right turn. No problem when making left turn. bulbs are all ok. fuse is ok. any suggestions?
I believe the problem lies within the hydrochromatic gauge located under the steering capacitor. But I don't see why you use your turn signal anyway, when it just burns out the bulb.
Nov 21, 2009 | 1994 Isuzu Rodeo
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Jun 29, 2008 | InFocus IN72 Multimedia Projector
Philips HDTV wont turn on
If your model number is 60PP9202 you dont have a bulb, you have three CRT picture tubes instead, and if the power light doesnt come on check the fuse on the power board. Remove the rear cover after unplugging the cord and look at the small board on the irght where the power cord attaches you will see a fuse its most likely blown.
Jun 27, 2008 | Philips 60PP9202 60" Rear Projection...
Hp VP121 needs new bulb?
Hi there
Take out the lamp and check for any marks on the inside ( shaft ) of the lamp. If there is marks or discolouration on it then you can be 100% sure it is the lamp.
Apr 10, 2008 | HP VP6121 Multimedia Projector
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Light Bulb Replacement On JVM 1860SF001
You can find an exploded view diagram by entering your model number (without the space) here: http://www3.sears.com/ That diagram may help.
Mar 23, 2007 | GE JVM1860 Microwave Oven
Samsung HL-P5063W 50" Rear Projection HDTV Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
