Question about Philips 32PFL5403D/27 32 in. LCD TV
My Philips 32PFL5403D LCD TV does not turn on and blinks 6
My Philips 32PFL5403D/27 32 in. LCD TV does not turn on and its LED blinks 6 times in red, stops and blinks 6 again continously. This started only after 1 week of use.
    President:
  • 1,077 Answers
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 15, 2009
Sometimes it turn on. But if we switch off once it won't on.At least for 2 to 3 days it happens. Please reply
Posted on Jun 10, 2013
?when I turn TV on I get a red light blinks 1 time then 2 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 17, 2016 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
Philips 32" tv will not turn on flashing three
hi,
You have to check the power supply of you tv for any voltage missing. also check the back light inverter board for any short circuit in it. Inverter transformers in the back light controlling board can become faulty.Three blink indicate the power supply have some problem. First of all replace all the electrolytic capacitors in the power supply board. If filter capacitors in the power supply is bad then this problem can occur.
ok
Jun 09, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
I cannot install terrestrial digital tv on my Philips LCD TV 32PFL5403D/10 and it states that it has a digital tuner installed.
DVB-T can be translated in Mpeg 2 or H.264 (Mpeg4) format. Check if you have correct tuner installed for you local provider
Jun 02, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Red blinking led
My 42" Philips LCD did the same red blinking sequence last night. All was seemingly fine after unplugging it for a bit. An online search, though, has me worried that this may be the start of (potentially fatal) power supply issues. Anyone have a clue what that sequence means?
I've got one week left on my 1yr waranty, so I'm a bit concerned! :(
Thanks!
Jan 15, 2008 | Philips 32PF7320A 32 in. LCD Television
Philips 32PFL5403D/27 32 in. LCD TV Logo
1,488 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
