Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Any idea where I can get a kd board for this model? Sony kdf-42we655
  • Dino McCleary Jul 15, 2009
    Thank You so much.
  • Sony Master
  • 8,617 Answers
You can get a new replacement board at the following link. Listed under Sony Circuit Boards.
http://www.tvrepairworld.com/
Posted on Jul 15, 2009
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF 42WE655 Red lamp flashes 10 times what error code is this?
The ten blinks indicate that you do not have the 5 volt output from your DTL module on either board one or board two.
Oct 18, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I replaced the lamp and now my left speaker makes a sound as if its not conected correctly, then the tv turns off and the red light blinks seven (7) times, pauses and blinks 7 times again.
7blinks is an error code for "Audio Error". This kind of symptoms is an indication of fault either on the KD board AKA Audio board or the G1 board (supply line for audio board).
You have to isolate the fault between the two boards by measuring the supply line for the audio board. If the supply voltage is intact this is an indication that you need to replaced the KD board. If there's no output voltage from G1 board feeding the KD board, then you have to replaced the G1 board.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Oct 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have Sony TV model KDF-42WE655 which stopped working. No display and when powered on, the green light comes on and blinks approx 50 times and turn red (blinking red). How and what do I need to buy to fix...
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony kdf-42we655 has 7 flashing red blinks. please help.
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Jun 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 2004 Sony LCD projection TV. The set
It is symptom of weak Lamp (bulb) that requires replacement.
You can buy Sony original lamp from Sony Accessories Store.
Lamp required for KDF-42WE655 part number is as follows..
A1606034B LAMP BLOCK XL-2100U
May 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
6 flashes
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
also check out this sony recall
http://www.hdtvoice.com/voice/showthread.php?t=31861
Jan 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
