Toshiba TECRA 8000 13.3" TFT LCD Display LQ133X1LH13 P000258380 CD-ROM Drive
Problem for Toshiba TECRA 8000 13.3" TFT LCD Display LQ133X1LH13...
Toshiba 8000 system disc message
By larry_lehr on Jul 15, 2009
we have a Toshiba 8000 that boots up with a message: "insert systems disc". We have not had this problem before, and don't have a system's disk. I have noticed other people have had a similar problem. Do you have any suggestions.
Best Solution
posted on Jul 18, 2009
Very Helpful)
Crankstart
Rank: Guru
Rating: 92%, 293 votes
Hi Larry,
This happens when either the system disk is corrupt or faulty, or, when another disk with higher priority but no operating system is in the computer.
Typically removable disks like CD's, DVD's, Floppy disks, Memory Cards and USB flash drives can all take higher priority than your windows drive as any can be used to load up diagnostic software when it is damaged.
So, Remove all disks, USB devices(including printers), CD's or DVD's et al and try again. If this still happens with everything removed/disconnected, then your problem is with the Windows install or the harddrives physical components. If it works try reattaching/inserting the disks and devices one at a time then restarting and you will figure out which one is causing the problem.
If it didn't work you will need to get to a hardware shop and have them test the hard drive to see if it's faulty. If not contact Toshiba and order a set of recovery disks, when they arive insert disk one then turn the machine on and an onscreen wizard will walk you through re-installing. If they determine there's a hardware issue with the drive, either buy/warranty a new drive then order the disks from Toshiba and follow the above instructions.
Hope this helps FixYa,
Chris
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Toshiba TECRA 8000 13.3" TFT
Questions and Unsolved Problems for Toshiba TECRA 8000 13.3" TFT
Do you recommend Toshiba TECRA 8000 13.3" TFT LCD Display LQ133X1LH13 P000258380 CD-ROM Drive?
Answer
Answer
windows xp-installed a hitachi cdr 7930 as a slave on secondary to primary toshiba dvd rom that was... (More)
Answer
Hi there My Toshiba Tecra PTA40A will not recognise their is a CD/DVD rom. Was fine but now sounds... (More)
Answer
my toshiba tecra m2 has constant vertical line about three quarters of the width of the screen to... (More)
Answer
I'm considering buying a toshiba 8000 and the current owner cannot remember the password, how would... (More)
Answer
i have a toshiba tecra 8000 after wiping it and installing xp i cant get the av out to pick up tv. i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD ROM Drive Experts
Top Computer & Laptop Repairmen
in , OH
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
