How to replace power cord?
Replacing a power cord is fairly straightforward for those who already have a little experience.
The power cord is either obtained as an assembly as a spare part for your machine or bought as a simple length of cable from the local hardware or electrical shop. If the strain relief grommet is moulded onto the cable an assembly will probably be needed.
Carefully removing the existing lead will provide a pattern with the correct dimensions to cut the replacement, remove the insulation, etc.
Appliances use a variety of methods of connecting the power cord into the internal terminal block but which screws to remove is usually an intuitive process.
