Question about Beverage-Air BM-23 Keg Refrigerator - Black
I own a Beverage-Air BM23-2 kegerator. This is not a problem but rather a question with regard to attaching an external digital temperature control. I want to attach it to the right side of the kegerator (assuming you're looking directly at the its front/door). The prefered location is in the upper left corner of the right side. The controller is approx 2.5"x 6.5". It would require 2 short screws to mount the controller. It would also require one hole drilled all the way through the side in order to run the sensor cable which is about 0.25" thick. Will I be drilling into foam only or is there freon tubing to avoid?
  • mhampton104 Jul 15, 2009
    You say to verify the location of the condensor lines . . . would they be visibe on the exterior of the back of the kegerator? I don't recall any exterior tubing and the kegerator is not available to look as I am at work.
  • mhampton104 Jul 16, 2009
    Since I don't want to hit any tubes or lines, I feel better about doing this project based on the information provided by Fixya. The response was very reassuring and very fast. Thanks for your help! Mark
  • 3,037 Answers
You should be fine as the condenser lines are on the back wall of this unit if I am not mistaken. Verify that, but nothing should be in the way on the side walls. Unless you have something you have added to the inside that you then would need to worry about.
Benjamin
Posted on Jul 15, 2009
  • Benjamin Patri
    Benjamin Patri Jul 15, 2009
    The lines/coils should be near the compressor which should be visible on the unit bottom/back side.
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Resealing lid on a Beverage Air DD58 kegerator
The only way I have found to seal those tops back down is with 100% silicone caulk, NOT LATEX OR BUYTAL, silicon.( We use 3m.) Then hold it down with cinder blocks for at least 24 hours then you are in business.
Mar 21, 2014 | Beverage-Air DD58 Beverage Cooler
I'm trying to find out the age of my Beverage Air BM23 Kegerator. It's serial number is #823620I.
Scott,
Your Beverage Air Kegerator model BM23 / serial: 823620I - that serial didn't bring anything up when I called the manufacturer but based on the first 2 digits of the serial and the roman numeral 1 at the end of it - it would appear that your unit was manufactured in 1982 (If that number was on a metal tag then it defiantly was 1982).
We specialize in cooler gaskets and can help you locate the gasket part your unit needs. We also are able to get many other hardware and accessory parts for Beverage Air units and other manufacturers. Let us know if we can help.
Matt at coolergaskets.com
orders@coolergaskets.com
855-288-2259
Aug 25, 2013 | Beverage-Air BM23
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air BM-23 Keg Refrigerator - Black Logo
163 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
