Question about Homelite Mighty Lite Lawn Trimmer
Pull string stays out
I have a homelite mighty lite bought it like new referbished the string stuck out.I took it apart and it went back in.I seems to be binding inside but cannot figure out why.I lubed the mechanizm but when i put it back together it stay out . the pull start works fine until I put it back together walla binds up again. Is there a part missing ? It bound up before I took it apart.Is this some manufacturing deffect.
SOURCE: Brand new Homelite Mighty Lite 26cs String Trimmer
carb setting is too lean,need special tool to open,go to mower shop.This model also has problems with starter mechanism,I hope you have a warranty
Posted on Jun 14, 2009
  • 6 Answers
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Posted on Jun 19, 2009
  • 59 Answers
SOURCE: pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Posted on Jun 27, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
SOURCE: How do I feed string into my Homelite Mighty Lite
cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Posted on Jun 03, 2010
Testimonial: "Thank you! Your response helped me troubleshoot."
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Pull start
Good chances is that the cord either got pulled to far out or the spring let go inside the cover that controls the rewind. It's not a big job...just remember how you took it apart www.nnyparts.com
Jun 01, 2010 | Homelite Mighty Lite Lawn Trimmer
Pull cord stays out, won't retract. I took apart
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Refill string trimmer
ARE YOU WINDING TO LINE THE RIGHT WAY ON TO THE SPOOL?? FOLDING THE LINE IN HALF AND WINDING BOTH ENDS OF LINE SAME WAY? NEIL
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
276 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
