Question about Hotpoint TDL15 Electric Dryer
How do you install the belt on the tumble dryer
    President:
  • 1,714 Answers
Watch the video;
Posted on Jul 15, 2009
  • 20 Answers
SOURCE: insalling a tumble dryer belt
The top of dryer hindged, snap clips in front, pop clips with scewdriver, front panel should slide up and out or tec scews along inside edge, motor should be on your right side facing drum, motor bolted to botom plate, need to check belt tennsoiner for any type of wear and damage,the rest should be simple,re-assemble dryer.
Posted on Jan 03, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
  • 1122 Answers
SOURCE: how to change a drive belt on a candy CDC266 tumble dryer
don't know what make you have but if you go to sears .com click on parts put in your model number(inside dryer door)you will find a break down of everything you need to know,let me know how you do-mike
Posted on Oct 12, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: tumble dryer ,creda tcr 13
hello dave to do this you'll have to take the front panel off so you can pull the tumbler out so you can get to your pully and tensioner on the bottom on the dryer,loop the belt on the pully and keep tension on it while you slip the tumbler back in now loop the belt around the tumbler and after the tumber is sitting on your glides spin the tumbler till the belt is in place,if you can have somebody help you its easyer putting the tumbler back in with 2 people while keeping the belt on the pully on the bottom of the dryer. any other problems or questions let me know i've dont mine about 6 months age its a little pain in the **** but not inpossable
Posted on Apr 09, 2009
dragonsthatk
  • 547 Answers
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Posted on May 02, 2009
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
How to access belt on indesit idv65 tumble dryer
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
Jun 22, 2012 | Dryers
Need to replace belt on vtd20g hotpoint tumble dryer
May 10, 2012 | Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
How do i replace drive belt on an indesit is60v tumble dryer please
Sep 09, 2009 | Dryers
My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip.
Jun 30, 2009 | Maytag SDE2606 Electric Dryer
Dryer won't tumble
are you sure you installed the belt properly ? a lot of dryers have an idler pully that the belt has to go through to create the correct amount of tension. that's about all there is to check
Jan 23, 2009 | Whirlpool GEQ9800P Electric Dryer
Hotpoint TDL15 Electric Dryer Logo
359 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
