well lots really, A/T box have huge list of causes.
My answer is USA cars here. (scans)
4-speed ZF 4HP16 automatic what is is this.
there is no 5th, so 5 is TCC lock up only but sure feels like it sure.
what to do is this.
1: check all fuses. (
2:
scan the PCM for DTC errors P07xx errors
3: check oil level of box, by reading the glove box guide. , hot engine, in park at idle , fluid at top mark (hot) never ever overfill the transmission. or boom. happens.boom and doom;(yup)
skipping 3/4 gears causes. (my guess skips 3 and goes 4th+TCC)
transmission in limp home (scans tell why , so scan it) skips gears.
transmission bad speed sensor , scans told you which failed.
transmission some of 6 solenoids fail , again scans.
or worse, leaks inside the box (seals vast) cause the main gallery ATF pressure to not be correct for 3 or 4 clutch is bad.
3/4 gear is not flare or flash neutral right. just skips the gear
from 2 to 4 right shifc, huge engine RPM drop, that.?
most boxes (TCM logic) only allow TCC lockup on 4th gear.
so 3 is bad, skips. (but ZF boxes I do not know well, GM yes )
transmission= box , transbox. slangs.A/T box.
LISTING EVERY CAUSE IS SUPER LARGE LIST(stop)
HOW TO DIAGNOSE IT, IS WHAT IS TO BE DONE
AND THEN IF there are ON car cures, and above is my list.
even 1 bad $1 seal deep inside a box can make it fail .
The box service manual as huge list of pump pressure test.too.
beg ,barrow, rent or buy a scan tool, or get it scanned in a shop
in the USA a 2008 or newer scan tool real is best not $17 code readers. one needs to see all codes (DTC) errors even factory only codes. OK?
