Question about Boating
Can not get off simulate - Boating
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 14 Answers
Assuming you're talking about a Depth Finder or a GPS... if it's depth finder, I had a similar problem on a Humminbird Depth Finder... the issue was holding down the power button too long. If you push it long enough for the system to light up and let go, it should solve the problem. Holding it down longer takes it into Simulation. Hope that helps.
Posted on Aug 10, 2009
I what to know how to input simulation program to clear maintanance code CA on Mx2610 sharp copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Feb 10, 2016 | Sharp Office Equipment & Supplies
Tip
BlackBerry Error Code
When using the <i>BlackBerry</i> device <i>simulator</i>, you can sometimes meet this Application <b>Error inside JVM</b> Access Violation Reading 0x00000000 when you try to start the simulator. Here's how to solve your problem.<br /> <br /> <b>BlackBerry simulator ERROR</b>:<br /> <br /> <ul> <li><i>Application Error <br /></li></i> <li><i>Error inside JVM: <br /></li></i> <li><i>Access violation reading from 0x00000000</i></li></ul> Open the folder to install the <b>simulator BlackBerry</b> for example: C: \ Program Files \ Research In Motion \ BlackBerry Smartphone 4.6.1 simulators \ 4.6.1.199 (8900) if there is a file called clean.bat use it. Try to open the <b>simulator,</b> and if you get Error inside <i>JVM: Access</i> violation reading from 0x00000000 error again, close to the simulator, open the installation folder again and delete all. DMP files to be installed in the folder and start the mortgage again.<br /> <br /> <b>If this fails, try the following</b>:<br /> <br /> <li>Uninstall the JDE SDK and the BlackBerry Simulator</li> <li>Reboot your PC - do not bypass this step</li> <li>Install JDE SDK and the BlackBerry Simulator</li> <li>Start the Simulator</li>
on Dec 14, 2010 | Cell Phones
How to activate simulation mode mx-m264n
OR
When the
Aug 25, 2014 | Sharp M264N Copy Machine
Gps-simulator
The GPS Simulator mode is a mode where the unit will not look for satellites. instead, it will show simulated satellite receive signals on the satellite reception screen and allow you to simulate driving to the destination that you programmed into it. You will be able to see each turn just as if you were really driving on the road.
Apr 23, 2013 | Garmin nuvi GPS
Sharp AR-M550 with a paper tray error F3-12
1. Start and end of simulations Note: The "PAUSE" key in the descriptions means the "INTERRUPT" key. Simulation IN The Simulation IN mode becomes only available from the Copy mode screen. In the simulation mode, printer operation is inhibited. Printer operation is also inhibited in either of the Aging mode or the Adjustment Copy mode. The printer selection key is disabled, too. By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation main code input screen appears. * If the interval between any two key operations is more than 5 seconds, the entry into the simulation mode is canceled. (Ref.) 1 ~ 9: Loading/ sensor checks 10 ~ 19: Resetting troubles 20 ~ 29: Counter/mode setting 30 ~ 39: Sensor activation checks 40 ~ 59: Adjustments 60 ~ 69: Digital readout and printer Simulation OUT The simulation can be terminated by pressing the [CA] key. 2. Simulation main code input screen SIMULATION NO. _ INPUT MAIN NO. AND PRESS PRINT SWITCH 1 If any trouble has occurred when the trouble code is requested, the 7-segment readout displays the trouble code (main only). [Note] The trouble code is canceled when the copier enters the simulation IN mode. [Note] The 7-segment readout becomes blank when the copier enters the simulation IN mode. 2 Only the [PRINT] key LED comes on. [Note] The [PRINT] key LED is usually OFF. It comes on when the copier waits for the [PRINT] key to be turned ON in the simulation mode. 3 The main code input area (2 digits) waits for the input of a main code. [Numeric Key]: Main code input [Note] Codes are entered in the ring format. [PRINT]: Sets entered data. [C]: Clears entered data. [CA]: Terminates simulation. [Others]: Cancels (ignores) entered data. 4 If a simulation has a sub code, it should be executed on the sub code input screen; a simulation does not have a sub code, it should be executed on the simulation execution screen. 3. Simulation sub code input screen
Dec 08, 2009 | Sharp AR-5320 Black and White Copier
My garmin nuvi 360 goes in simulated driving mode
if you recently plotted a course and used the simulation mode, it will stay there either till you deactivate it, or you arrive at the destination. go to the simulation mode and see if its in simulation, if so, stop it.
Aug 06, 2009 | GPS
Reset drum
Hello sir; after you replaced drum there have 4 simulation you have to do;
1, simulation26-7 to match the first digit of the four digit printedon drum.
2, simulation 24-7 drum film wear correction counter reset.
3, simulation 44-6 patch forming voltage.
4, simulation 44-2 drum mark senser level standard value is 90.
To get in simulation the procedure as follow;
1, press "clear", 'pause", "0", "pause". then enter the simulation number one by one. GOOD LUCK !!!
Jun 02, 2009 | Sharp Office Equipment & Supplies
Where can i find more planes for esky flight simulator
Go to YAHOO! and search "add-on aircraft for esky ch4 flight simulator. GOOD LUCK!
May 17, 2009 | E Sky Flight Simulator Training Kit
Boating Logo
88 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
