Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Cannot access my flash drive. When I check Device
Cannot access my flash drive. When I check Device Manager it says the following: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) The driver installed is Microsoft 6.0.6001.18000 dated 6/21/2006. This is for a SanDisk cruzer micro 2GB.
  • mike_kearns_ Jul 15, 2009
    Thanks for the advice justin. I was able to backup my data onto another pc. Unfortunately my desktop still does not recognize the flash drive when I plug it into the usb port. The light on the flash drive comes on. But when I go to "my computer" it says there is no disk inserted, therefore I can't access my data or even reformat the drive.
  • 85 Answers
Backup your data (if you can) and reformat the drive by right clicking on it in my computer-then reformat to fat32. This probably will solve your problem. I hope this helps!
Posted on Jul 15, 2009
2 Suggested Answers
  • 24 Answers
SOURCE: sandisk 2gb cruzer micro usb broke
if the usb connector broke off of the board inside the plastic casing, no, you wont be able to retrieve the data.
Posted on May 30, 2010
Testimonial: "it doesn't help me get my info back but it helps that someone would take the time to let me know that it is trash now, so that i don't hold on to it always wondering how to fix it. so thanks"
Lg Optimus F6 will not recognize micro sd card
Click Start, then type device manager in the Search box, then click Device Manager.
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete, restart your computer. Your USB controllers will automatically install. If the method fails you can try the following method: Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Oct 30, 2013 | Samsung 16 GB Gigabyte Micro SDHC Memory...
What can i do? my jetFlash V85 is unknown
Connect your flash drive to your computer using an available USB port.
If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive.
A question mark icon should be shown to the left of the label.
Right-click the device name and select "Uninstall."
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes."
This will scan your PC for any new devices.
Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
Click "Start" > "My Computer" and look for your flash drive.
If this process was successful, your flash drive should now show up under My Computer as a storage disk.
If its listed as an unknown device
Then right click on your flash drive select rename
Hope this helps
Nov 08, 2012 | Electronics - Others
Windows Xp not recognise my USB TS4GJF110
To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
Aug 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Dvd cd rom [ code 10 ] does not work
The Code 10 error code is generated when Device Manager has insufficient information or the error that is bubbled up by the device drivers is not recognized by Device Manager. Additionally, this error may occur when one of the drivers that the device needs does not start. If many drivers are being used by a particular device, it can be difficult to determine the one that failed.
The Code 10 error resembles the following: This device cannot start. (Code 10) The most common resolution is to update the drivers that are associated with the failing device. To do this, follow these steps:
  1. In the device's Properties dialog box, click the Driver tab.
  2. Click Update Driver to start the Hardware Update Wizard.
  3. Follow the instructions to update the driver.
Note You may be prompted to provide the path of the driver. Windows may have the driver built-in, or the driver files may still be installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site. uparrow.gifBack to the top Typical Code 10 error issuesThe Code 10 error pertains mainly to hardware and device driver issues or to compatibility issues between hardware drivers and additional software that is installed in Windows. Therefore, we recommend that you troubleshoot these issues by focusing on device drivers, on device configuration issues, and on hardware compatibility issues. Incompatible, outdated, or corrupted device drivers If you suspect that the Code 10 error is related to incompatible, outdated, or corrupted device drivers, try the following troubleshooting methods. Method 1 Update the hardware's device driver through Windows Update. To access Windows Update, visit the following Microsoft Web site: http://update.microsoft.com Method 2 Update the device drivers from the vendor's Web site. Follow their installation or update instructions.
  • If the device was preinstalled on the computer, visit the computer manufacturer's Web site.
  • If the device was installed after the purchase of the computer, visit the device manufacturer's Web site.
  • If the device was preinstalled on the computer, and the computer manufacturer does not have an updated driver for the device, visit the device manufacturer's Web site.
Note Make sure that the device drivers that are being installed are compatible with your current Windows version and platform.
Note In reviewing customer feedback, many of the Code 10 error issues are related to devices connected by using a USB port. As mentioned earlier, make sure that you have the most current drivers installed for the device together with any updates for Windows. In the specific case of Windows XP, review the following article to determine whether it applies to your situation: 925196 A computer that is running Windows XP cannot detect a USB flash drive, an Apple iPod, or an external hard disk drive
If you are running Windows XP and cannot install Windows XP Service Pack 3, review the following article to determine whether it applies to your situation: 940514 USB devices do not work after you disconnect and then reconnect a USB hub from a computer that is running Windows XP Device configuration issuesIf you suspect that the Code 10 error is related to missing software updates and service packs, try the following troubleshooting methods:
  • Install the latest Windows service pack.
  • Use Windows Update to install the latest updates for Windows. To do this, visit the following Microsoft Web site: http://update.microsoft.com
  • Install the updates that are specific to the computer or to the device. To do this, we recommend that you visit the computer manufacturer's Web site or the device manufacturer's Web site.
Software and operating system updatesIf you suspect that the Code 10 error is related to missing software updates and service packs, try the following troubleshooting methods:
  • Use Windows Update to install the latest updates for Windows. To do this, visit the following Microsoft Web site: http://update.microsoft.com For more information about how to obtain the latest Windows service pack, click the following article numbers to view the articles in the Microsoft Knowledge Base: 322389 How to obtain the latest Windows XP service pack 935791 How to obtain the latest Windows Vista service pack 889100 How to obtain the latest service pack for Windows Server 2003 968849 How to obtain the latest service pack for Windows Server 2008
Jun 12, 2011 | Dell Computers & Internet
USB port not reconizing
The time delay depends on the following factors:
  • Host controller hardware
  • Attached hubs
  • Attached devices
  • USB driver versions
  • Support for USB 2.0
  • Additional system hardware or configurations that may change the timing
Method 1: Initiate recognition of the USB device by using Device ManagerTo initiate recognition of the USB device by using Device Manager, follow these steps:
If this method resolves the issue, you are finished.
Method 2: Restart the computer To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus (http://support.microsoft.com/contactus)
Dec 22, 2010 | FireLite (USBFLB80) Hard Drive
My kingston 2 gb flash disk is not recognized, how can i fix it?
Please follow the below steps to fix your problem
Connect your flash drive to your computer using an available USB port. If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double-clicking the "System" icon.
Click the "+" next to "Disk Drives" and locate your USB flash drive. A question mark icon should be shown to the left of the label. Right-click the device name and select "Uninstall."
5
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes." This will scan your PC for any new devices. Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
6
Click "Start" > "My Computer" and look for your flash drive. If this process was successful, your flash drive should now show up under My Computer as a storage disk.
Hope the above information will be helpful to you.
Thanks.
Oct 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
Apr 21, 2010 | Computers & Internet
This printer worked fine till windows 6 explorer was installed what happened?
You might have a Driver issue.
Usually, a driver update isused as a solution to an issue with how Windows works with a piece of hardware.
Updating a driver can also enable new or updated features for the hardware.
To access Device Manager, use any of the following methods:
  • Click Start, click Run, and then type devmgmt.msc.
  • Right-click My Computer, click Manage, and then click Device Manager.
  • Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager.
  • Type the following command at a command prompt:start devmgmt.msc
You can use Device Manager to change the way your hardware isconfigured, and to change the way your hardware interacts with yourcomputer's programs. With Device Manager, you can update device driversfor hardware installed on your computer, modify hardware settings, andtroubleshoot problems.
Device Manager enables you to:
  • Determine if the hardware on your computer is working properly.
  • Change hardware configuration settings.
  • Identify the device drivers that are loaded for each device and obtain information about each device driver.
  • Change advanced settings and properties for devices.
  • Install updated device drivers2_bing.gif.
  • Disable, enable, and uninstall devices.
  • Reinstall the previous version of a driver.
  • Identify device conflicts and manually configure resource settings.
  • Print a summary of the devices that are installed on your computer.
If the device is experiencing a problem, the type of problem isdisplayed. You might also see a problem code and number and a suggestedsolution. If you call a support line, this number can be useful fordetermining and diagnosing the problem.
How to install a new driver from Device Manager loadTOCNode(2, 'summary');
  1. Double-click the type of device you want to update or change.
  2. Right-click the specific device driver you want to update or change.
  3. Click Update Driver to open the Hardware Update Wizard. Follow the wizard instructions.
Rolling back to a previous version of a driver loadTOCNode(2, 'summary'); Use this feature if you encounter problems after you install a driver,such as error messages when you access the device, faulty behavior ofthe device, or even the inability to start Windows.
Windows XP2_bing.gif provides this roll back to a previous, working, device driver:
  1. Right-click the device for which the previous version of the driver is desired and then click Properties.
  2. Click the Drivers tab.
  3. Click Roll Back Driver.
If you cannot resolve the problem with these instructions, contact the manufacturer.
Dec 04, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have 12 Drives All 12 Drives are found but when I burn a DVD The Some drivers fail and it is not the same ones all the time
Usually, a driver update is used as a solution to an issue with how Windows works with a piece of hardware.
  • Type the following command at a command prompt: start devmgmt.msc
You can use Device Manager to change the way your hardware is configured, and to change the way your hardware interacts with your computer's programs. With Device Manager, you can update device drivers for hardware installed on your computer, modify hardware settings, and troubleshoot problems.
  • Install updated device drivers.
If the device is experiencing a problem, the type of problem is displayed. You might also see a problem code and number and a suggested solution. If you call a support line, this number can be useful for determining and diagnosing the problem.
Rolling back to a previous version of a driver loadTOCNode(2, 'summary'); Use this feature if you encounter problems after you install a driver, such as error messages when you access the device, faulty behavior of the device, or even the inability to start Windows.
Windows XP provides this roll back to a previous, working, device driver:
Dec 04, 2009 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
E DRIVE DISAPPEARED FROM LAPTOP (ACER)
this is a known issue check the microsoft website on how to work on this,. look for the part where you need to do something with your registry.
Dec 18, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
1,202 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
