SOURCE: torch is used for jewelry work and is a acetylene
Usually, the blow-out problem is caused by excessive fuel flow at first--too much pressure or valve is opened too far. Once you have a bushy acetylene flame, turn up the air source to bring the flame down to a fuzzy point near the tip end. Brazing and silver soldering work better with just a little less air. My experience is with an oxy-acetylene torch, but results are similar.
SOURCE: How do I service Oxy-Acetylene gas welding mixer
sounds like your needle valves are worn or damaged,also change allthe q rings in same valves
SOURCE: Hi there, despite brand new
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
