Question about Bunn 10 Cup Home Coffee Brewer
I have a new Bunn coffee maker and every time I make coffee it get a little puddle under the maker in the back! What is causing this???
  • 20 Answers
You might be overfilling the unit or the unit might be defective from the manufacturer.
Posted on Aug 07, 2009
My Bunn coffeemaker is leaking water after it stops brewing and the coffee doesn't seem to get as hot as it once did. It also only gives back 4 cups for a 6 cup brew.
if you unscrew the top there's a rubber seal in there that you might have to replace that causes the leaks. also clean your coffee maker regularly with vinegar.
my husband had to replace the seal in ours 4 times but after owning the same Bunn for 20 yrs it was time for a new one
Jan 18, 2011 | Bunn 10 Cup Home Coffee Brewer
BT10B Coffee Maker: When I use Dunkin Donuts coffee in my Bunn coffee ...
Dunkin Donuts is a finer ground coffee and the water comes through so quickly that it isn't absorbed quick enough so you don't get the full flavor and it causes an overflow. If you will call Bunn Customer Service, a new flow restrictor can be sent to you to resolve this problem.
May 17, 2010 | Bunn BT10B Coffee Maker
My Bunn coffee pot leaks water theres always a puddle of water under the pot.coffee pot is over half full
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Sep 13, 2009 | Bunn NHB Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Bunn Cooffee Maker is not making full pots of coffee
I would ask if this machine has been moved lately- for cleaning or has anyone put anything new around the brewer? If someone has moved this brewer, they might have caused a kink in the line coming to the back of the brewer. this will restrict the water flow to the brewer. this will cause the brewer to brew only part pots of coffee.
Nov 13, 2008 | Bunn NHB Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn 10 Cup Home Coffee Brewer Logo
76 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
