Question about Ricoh FAX2050L Plain Paper Laser
Check Display The ''check display'' light keeps flashing. How do I clear this out?
Usually it's a paper jam. remove cassette, and look inside...there may be a piece of paper stuck inside. Also remove, and re-seat all paper in the cassette. Also, remove toner cartridge, and check inside the machine cavity for jams..
re-post if problem remains.
Posted on Jul 15, 2009
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Keeps switching inputs
WD82837: Mitsubishi 82" Rear Projection
Problem: The "status" light flashes yellow while no picture display. Nothing happens when pressing the power button. The light keeps flashing if plugged in. I cannot test for codes by holding for 5 seconds as there is no place to check the code problem due to no display. HELP!
Feb 07, 2014 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Message light keeps flashing on my Meridian M2616 phone after I have checked the messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Apr 16, 2013 | Nortel Lot 16 Meridian M2616 M 2616 Phone...
It flashes f2 & all the lights keep flashing
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Washing Machines
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Paper light flashing on my brothers HL-2040 printer. I fanned the paper still keeps flashing
Hello ,
Please follow the below steps to try and clear this message.
  1. Turn the power off on the unit.
  2. Open the front and back cover of the unit.
  3. Remove the drum and toner cartridge from the unit.
  4. Check thoroughly inside for any paper jams or any other foreign objects and remove them.
  5. Reinsert the drum and toner and close the front and back cover.
  6. Turn the unit back on.
If the light keeps flashing you will want to check to see if you need to feed paper through the manual feed.
The manual feed is the opening on the front of the printer, just place a page there.
This should clear the error message on the display screen and allow you to resume normal use of the printer.
Thanks,
Pat
Mar 28, 2010 | Brother HL-2040 Laser Printer
Oven self-clean won't turn off!!
You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
Nov 14, 2009 | GE Ovens
Message Light
press #409 to cancel message receive
press #64 follow by et\xtn on display to cancel sent message
mayb st 21 been assigned, but no body know.to check, call from all extn to displayed phone.check 1 by 1.
if light keep blinking for mic, try to change other key phone
May 27, 2009 | Toshiba DKT-2010 Corded Phone
Ricoh FAX2050L Plain Paper Laser Logo
157 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
