Cell Phones Logo
Darryl Jackson Posted on Jan 24, 2016
How to reset my lgl34c because of forgetting lock scene pattern.
I have a pattern lock on my wiko how can I get into it
How can you 'forget' a pattern lock you are using dozens of time a day! If it is stolen, it is probably PUK Locked.
Just do a Hard Reset
https://www.google.com/search?q=wiko+android+phone+hard+reset
2answers
How do I unlock screen pattern if I forgot my pattern on Asus zenfone 4
Hi Sheena
If you forget your pattern:
1. After you fail to unlock the screen in pattern for 5 times (4 dots at least), there will be a text sign of "Forgot Pattern?" appeared on the lower-right of the screen.
2. Tap "Forgot Pattern?" and then enter your Google account and password saved in this phone to disable pattern lock.Note: If you do not log in your Google account or the device is not connected to internet before the phone is locked, you will need to perform factory data reset in DROIDBOOT mode to solve this problem.
If you forget your PIN or password:
1. To reset your PIN or password, you need to in advance log in your Google account in your device and have your phone connected to Internet as well as Location function enabled.
2. Then, visit website below: https://google.com/android/devicemanager
3. Choose your device that you want to reset PIN. After your device is located, tap "Lock" in the wondow and reset your PIN.
7helpful
2answers
Hard factory reset phone LGl34C phone
You have not asked a question. If you have a problem with it, then let us know what it is.
Thank you for contacting Fixya.
Does this help? Let us know.
Mary Oliveau Xx's
Nov 25, 2014 • Cell Phones
Unlock screen on lgl34c
when ever you forget the
pattern lock and can't access the
phone, below is a step by step guide
on how to reset it.
1. Switch off the phone by pressing and holding the power button.
2. Now, press and hold the power button and the volume down button
(Power-on + Volume down button)
together until the phone has power on.
3. On the next screen that shows up, you should see about four ( 4 ) options, scroll down to "Factory Reset" or "Clear Flash" and select it. (Use the " Home button" or Switch button to select).
4. On confirmation, the factory reset process begins immediately. And,
when the process completes, the
phone boots up without the pattern security lock.
TIPS: For navigation purpose to explore
other options on the screen, you can
use the (Volume Down key) to
navigate down, the (Volume Up Key)
to navigate up and the (Home Key)
to select the option you want, you can use (Switch button) to select in some android phones
Nov 01, 2014 • Cell Phones
3helpful
HOW TO UNLOCK LGL34C
How to jail break the lgl34c
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
