Question about Lands Phones
Water was spilled on my GN8000. Ever since, the received call sounds VERY loud. Moving the volume slide doesn't do anything. Please help me to turn it down again.
  • 805 Answers
Plz serviceing ur mobile phone immediately otherwise ur phone circit will be dead for short circit. then hope everything become ok
Posted on Jul 18, 2009
What's up I have a uniden Washington no sound out of the speaker but it is receiving you can tell by the s meter moving.?
do you have the volume turned up? Squelch turned all the way left and RF gain all the way right. If you still don't hear anything check to see if this model has a dynamic squelch .If it does turn it off.
Sep 30, 2014 | Radio Communications
No sound from receiver
is the test tone loud or at the same level. you need to check the volume level of your player dvd, cd to make sure it's all the way up some players have volume level built into them.
Apr 12, 2014 | Audio Players & Recorders
Samsung wave no message sound
I have seen this one or two times with a few of my Samsungs but the only way I have found to fix it is to power off the phone and power it back on. If that doesn't work you might try going through the phone settings and un-checking/rechecking and sliding all possible sound options to make sure nothing is coincidentally set for this.
Mar 28, 2012 | Samsung Wave S8500 Smartphone
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
Im having kenwood home stereo system model no xd-v818 ...in high volume about 80 the sound starts to distoriate and the voice is not clear..i want to kno wether the stereo deck is not able to provide...
Well, here is the situation as I understand it. Here is also some theory to help you out.
Your Receiver or Amplifier has a "scale" showing relative volume. Distortion always increases in speakers and amplifiers when you turn them up. If the sound is getting extremely distorted, the Receiver is attempting to operate above it's maximum output. The scale is an average, but because music recordings are often mastered at different levels, "80" may be too much. When an amplifier section of a receiver is over driven, the distortion (which you observed) will damage or burn out your speakers. Most likely the tweeter (high frequency speaker)
If you back off the volume, or turn down the output of the deck until the sound becomes clear, then that level, IS FULL VOLUME. Based on what you are saying to me, I don't think anything needs service.
There is one other very important thing I should mention to you
. When people use high powered equipment and initially turn up the sound. After a short time, the mind turns it down. What next happens is the reason professional musicians and sound engineers often have permanent hearing loss after a relatively short time.
What happens is that the listener and often the engineer running the sound board at a concert thinks the sound is not loud enough (when the audience is happy with the level) and turns it up. After turning it up, his mind (and the audiences') turns it down and then he thinks it not loud and then again turns it up. And up. And up. The only reason I'm not deaf is that I discovered this when I was building sound systems as a kid. I also studied about it. So please be careful when you play things loud. Permanent hearing loss starts to occur at the very high frequencies and rolls down from there over a period of time. Hearing loss can start to occur in just a few hours.
at 110 decibels. It doesn't come back. If you understand this, you'll keep your hearing.
I hope this helps,
Best Regards,
Mark
Jan 22, 2011 | Audio Players & Recorders
The sound is very low, the volume needs to be on -27 to hear anything. When I first got it it was very loud, now I need to have the volume all the way up to hear anything please advise.
On the DSP board there are about 60x 10uF/16v capacitors that fail over time. Most of these are in the signal path and cause this issue.
They all need to be replaced. You can get them from maplin/charles hyde etc for very little money. Requires good soldering skills!
Jan 08, 2011 | Harman Kardon AVR 630 Receiver
HOW DO I TURN UP THE VOLUME
Users will continually need to quickly change the volume on a TOMTOM units, depending on the loudness of traffic noise, the radio or conversations. Although there are no external volume controls, the volume on the ONE can be easily accessed on screen by touching the bottom left corner of the map display. Once the volume controller appears you just slide your finger to increase or decrease volume. We found the audio levels a little softer on this unit and had to set the volume to around 60% or 70% in order to clearly hear it.
Please rate my help++++Thanks for using Fixya
Dec 12, 2009 | Tomtom One XL GPS Receiver
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
