Question about Whirlpool Duet GHW9150P Front Load Washer
The washer is flashing f 21, what does that mean?
  • 6,784 Answers
F22
CCU/Touchpad/LED assembly error
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding
2. Unplug washer or disconnect power.
3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.(In most cases, the CCU(Central Control Unit), will need to be replaced).
Posted on Jul 15, 2009
  • 5 Answers
SOURCE: What exactly does F 21 flashing on washer mean??
F-21 means that it's taking too long to drain. This could be a broken pump or some stuff in the pump or drain hoses. I had this problem last week and I fixed it myself with a pair of pliers and torque and phillips head screwdrivers.
If there is water coming out of the drain hose when it's running, then the pump is working. (The drain hose is the thing that comes off the back left corner and runs to an inlet against your wall.)
Unplug the machine and turn off, then detach, the hot and cold water hoses.
To clean the pump and drain hoses, you will need to take the back and top off. Very easy, just lots of unscrewing with the torque screwdriver. Have a little bowl handy for the screws. Then tip the machine forward, lid side down.
If the drain hoses are translucent, as mine are, you can see if they have gack in them. Unclamp them with the pliers. (Squeeze the things together and slide the clamp back up the hose it's holding on.) I had lots of gack (we're dairy farmers) and cleaned them with an unbent coat hanger with a piece of rag crimped on one end (use the pliers). There is a hose outside the machine and another one inside the machine. I also cleaned the elbow between them.
The two things inside the machine that you should clean are the rubber funnel that first takes water out of the drum (mine was black) and the pump it attaches to. These hose clamps were especially easy to unclamp. Take the funnel to the sink and wash it with hot water. The pump attaches to the bottom of the washer with red rubber seats. They are very easy to detach. Then you can take the light-tan pump on the left off the motor with the Philips screwdriver. Take the pump to the sink and clean it out. Mine had nails, a battery, money, a pencil and some other stuff. Remove any stuff and clean out both sides with hot water.
Then put everything back together.
This whole project should take an hour, maybe two. The Sears repair guy sucks and you don't need him.
Posted on Nov 05, 2009
jsrock516
  • 5911 Answers
SOURCE: my whirlpool duet sport washer flashes f-21 what
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Sep 15, 2009
SOURCE: My Washer flashes F 21
Your filter is probably clogged. Unplug the washer and remove the lower front panel (three hex screws). You may need to tip the washer back to do this - be sure to have someone hold the washer while you work. The filter is about 3 inches in diameter and unscrews from an assembly just to the left of the pump, which is on the right side of the washer. It is hard to turn, but with a little muscle it will unscrew. Be prepared for water to gush out. It can be a lot or a little depending on how much water is left in the tub. Once unscrewed, clean out all the junk that has accumulated in it. Make sure the the pump rotated freely and doesn't have any obstructions. Then screw the filter back in and put the panel back on. Assuming you found a lot of junk inthe filter, this should solve your problem. Good luck.
Posted on Mar 22, 2009
  • 572 Answers
SOURCE: I have a duet washer that on the display is
could be that its not draining properly. take toe panel off and clean the pump.
Posted on Feb 13, 2010
jsrock516
  • 5911 Answers
SOURCE: My washer is flashing "F-21"
"F21" is a Long Drain error code. This is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are both very simple repairs that you can perform yourself without the assistance of a repairman.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back with your MODEL NUMBER. I hope you find this information helpful.
Posted on May 20, 2010
What does F- and 21 mean
Error code F 21 means the drain is clogged...follow this advise for the Whirlpool washer as Maytag was bought by them
there is also this site for the washers http://fixedappliance.blogspot.ca/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
Jun 04, 2015 | Maytag EPIC MFW9700S Front Load Washer
My MAYTAG washer 9000 series with steam is flashing F21 and won't drain?
F 21 means slow drain if you can here the pump that means something pluging it. remove lower kick plate . the pump will be there remove cleanout counter clockwise turn .put back together.. hope this helps...good luck
Feb 01, 2011 | Whirlpool AWM9000 Front Load Washer
Washer machine will not complete a full wash it stops mid cycle and is flashing in the text box F 21. There is also water in bottom of the drum. What does F 21 mean and how do I fix it?
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Jul 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
F-21 flashing washer stops
The F-21 means slow drain. There is a filter in the front of the machine, you have to remove the bottom front piece to get to it. The screws are on the bottom. You then will have to open the filter. It is a white tube. Mine was pretty tight. Be prepared for water to pour out. I have had to empty mine twice in the 2 years I have had it. Hope this helps.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Load stops and flashes F-21
F-21 is a code that indicates "long drain".Check the drain line for kinks or obstructions. Check the pump. Check eletrical connections at the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mar 18, 2009 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
219 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
