Question about Canon MV30i Mini DV Digital Camcorder
Canon mv30 and mv30i won't eject tape
I've now had 3 mv30's and 2 mv30i's and they have all failed with the same problem: eventually the tape get's stuck in the mechanism, and major surgery is needed to get the tape out (destroying camera in one instance)
I have used the camera's for wedding videos and school productions, as they have been great shooters, but this seems to be a design fault. I don't know what needs fixing...
  • 6 Answers
SOURCE: Canon MVX200 will not load dv tape
The "remove Tape" error message on Canon DV camcorders is a general message meaning something is not correct with the tape transport system. These are miniature precision mechanisms and It could be anything from dew sensors to head motor, capstan drive etc. If the cassette drawer closes OK with no tape inserted then the tape sensor/ end tape sensor is operating. With no tape inserted the head drum does not run when the drawer closes but it does with a tape present. Does the head drum start up when you load a tape or is there no noise at all? If the head runs then it is possible the capstan is not starting or is jammed. If the head does not run then the cure will be either extremely tedious and delicate or very expensive. These units do not dismantle easily so unless you have some experience with this, or are willing to take a risk, then I would not recommend it. However, without such action you may have to write-off the unit anyway. Canon's repair charge will exceed the camera's value unless it's still under warranty. Your best option would be to find a local repairer that is willing to look at it, but I wouldn't be too optimistic .To some, this error message is a major issue when deciding to buying canon dv cameras. However, they are great little cameras and treated kindly will give many hours of excellent service. Don't store the camera with tapes loaded. don't subject it to sudden temperature changes or excessive vibration. Store it in a dry protected atmosphere and refrain from taking it onto the beach (salt AND sand !!!!) when on holiday etc.
Posted on Dec 18, 2007
SOURCE: Tape Ejection Problem
I have both the willful zoom and the unwilling cassette problems. In the past I have briefly fixed the zoom by opening the door and gently probing the cable to the zoom button. This only worked for a couple of weeks then reverted to same crazed performance. Then last month the "remove the cassette" madness started (bear in mind, I have only recorded perhaps 15 cassettes on this damn thing). Nothing worked. Until tonight when I simply lightly smacked the unit down flat on the manual resting on my desktop. Did this a few times and BOTH the zoom and cassette door started responding properly. I'll see how long this lasts, but it beats buying a new one or dealing with Canon. Never again.
Posted on Mar 09, 2008
SOURCE: Canona Elura 60 problem...
I had the same problem with my elura 60. I would put in a new tape, close the tape holder and wait for it to automaticaly lower so I could close the case. It wouldn't lower. It would just beep and eject the tape and display "please remove cassett". It would work just fine closing when there was no tape inserted. I tried all of the suggestions about warming it up, full battery charge, reset the camera, etc. I didn't want to pay a professional to fix it or buy a new one. So, I tried a new idea. I closed it all up, held it about 6 inches off of the ground (carpet), and droped it on the cassett side onto the ground. IT WORKED!!!
Posted on May 01, 2008
SOURCE: Canon zr300 ejects tapes
I just tried the "Fonzie" fix in my ZR300 and my camera now works - cassette compartment closes all the way now with the tape inserted. It just took one "hit" to fix the prolem. I was surprised. But ericemartin's solution is worth a try.
Posted on May 28, 2008
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Posted on Dec 18, 2008
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
I can't get to the film in the canon MV30
It looks like it is Empty from the Video, Are you sure you are not understanding what you are looking at?
Apr 05, 2013 | Video Cameras
My canon mv30i doesnt have a usb so i cant film and so put it on my pc :(
Purchase USB to 4-Pin 1394 FireWire Adapter cable. This will be very slow to transfer but should work and is a cheap solution.
Best solution of course is to buy and fit a FireWire port and cable to your desktop computer ( if that's what you are using ) and use that to download your video using the camera's FireWire port as intended.
Dec 07, 2012 | Canon MV30i Mini DV Digital Camcorder
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Camcorder chews up tape
clean the heads and rollers with cotton swab dipped in rubbing alcohol
Jan 06, 2010 | Canon MV30i Mini DV Digital Camcorder
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
Tape will not eject servo reaches halfway but sticks XL1s
Try this...
Hit the eject button. As soon as it makes it half way, take the battery out.
Leave the white cover open, put the battery back in.
This should take the tape cartridge up all the way and eject the tape.
I had the same problem and it ejected the defective tape
Kawal
Jun 23, 2008 | Canon XL1S Mini DV Digital Camcorder
Canon MV600i - Only recording sound, no picture displayed or recorded
Have you cleaned your drum lately. purchase a soft head cleaning tape and run it through there for 20 secs if that doesnt work then you need to send it in for repair.
Dec 24, 2007 | Canon MV30i Mini DV Digital Camcorder
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
Apr 21, 2007 | Canon ES900 Camcorder
Canon MV30i Mini DV Digital Camcorder Logo
393 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
