Question about Jenn-Air JJW8230D Electric Double Oven
Digital Display The digital display on our double oven is so faint that you cannot read it.
Re: Digital Display
July 8, 2009
My display went completely dead. Been dead for a while. Just today I fixed it. You have to change a small capacitor, on display board labelled C3. Very hard to find the exact one which is, 35V - 68 microfarad, so I replaced it with 35V - 100 microfarad. Works just fine. You have to be handy, or find a friend that can do this, cause you will need to solder.
Anyways hope this helps. By the way the capacitor cost me 15 cents canadian.
Good Luck
Posted on Jul 09, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Re: Digital Display
Is it the display board or the unit which supplies the power to the led unit. I dont want to buy the wrong part!
Posted on Dec 01, 2007
  • 248 Answers
Re: Digital Display
This is a problem with this oven. If under 5 years old there is probably a part warranty on the display board. You need to replace the display board.
Posted on Nov 18, 2007
0 characters
3 Points
Digital display is higher than actual temperature on oven
there is a thermal probe in the oven to the dispay controler it is a comm.problem on this unit,replace it and it should be fine,
Mar 17, 2014 | GE JTP48 Electric Double Oven
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Temp/clock display faded
its the display that is going out on the ovenlike everything else things just fad away. Actually I have had LED meter displays do the same thing.
Dec 23, 2008 | Thermador SC302T Electric Double Oven
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
there are 2 screws at the top outside and 2 or 3 on the bottom of the display panel. remove those and the panel should lift off the mount. remove the ribbon cable and 4 screws for the display and replace.
Oct 05, 2008 | DCS WO-230 Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
440 people viewed this question
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
