Question about Dishwashers
I had renters in my home and they lowered the top rack and now I do not know how to raise it back up. It is so low my plates do not even fit in the bottwom! How do I raise the top rack?
  • 441 Answers
Look on the sides of the upper rack, if you see tabs press them in while lifting the rack. If you see no tabs look at the side rails, if you see 3 sets of wheels then pull the rack all the way out and set it on the next set of wheels. Good Luck
Posted on Jul 15, 2009
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
My standard size dinner plates are too tall, the rotating part is catching the plates
Some machines have height adjustable top shelf.
Should be couple of clips on side of rack to raise / lower.
Other than that you will have to get smaller dinner plates.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Hi, I have a Westinghouse ADP6000WH dishwasher and...
You have to check the slider rails. If you watch the there be a different slot. You can remove and place it in that area.
Otherwise remove the top rack and run as special cycle for this dishes alone!!!
May 21, 2010 | Dishwashers
Fit top box rack on honda vfr800
you only use four make sure you put the spacers ond washers in the right place rubber washer plastic washersto the metal plate both sides then rubber washers then then metal washer then nut
Oct 09, 2009 | Honda VFR 800 Motorcycles
Height of top shelf to low for plates
sorry but that can only be remedied by a different unit
Sep 19, 2009 | Whirlpool 24 in. DU920QWD Built-in...
Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Jun 14, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Need a new control panel for Maytag mey12f7e
Call this number, they can get you a remote, probably the easiest and cheapest route
800.935.0062
Jun 11, 2009 | Maytag MEY12F7E Air Conditioner
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Go to Pinpoint Test D.
Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Jan 04, 2009 | 1989 Ford Mustang
Kenmore DW model 15999 Lower Spray Tower Came off
Yes, I was able to get it fixed.
The spray tower actually fits in the rack (I had thought it fit in the top of the lower spray arm - wrong!)
If you were to look at the spray tower itself, it has 2 little clip like plastic protrusions that with a little twist will clip onto the lower rack!
Push the lower rack in and you can see where the center would be, (right over the middle of the lower spray arm ).
Now pull out the rack and take the spray tower and slip it under the rack up thru the bottom in the position you noted was the center (from above).
Now with the spray tower in place, slide the rack back inside the dishwsher and you will see that the tower will be sitting directly over the top of the exact middle of the lower spray arm.
Voila!
Nov 22, 2008 | Kenmore 24 in. 15999 Built-in Dishwasher
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
