SOURCE: NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
SOURCE: Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Hi mohammad arshed, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?check the question and edit it to include make and model we can not assist without this information
