Question about Digital Blue iUbi Blue Digital Media Player
Battery smelt and the machine become bigger and broken
    Sergeant:
  • 449 Answers
Betteries are gone becuase of overcharging or compltion of life. Require repair from a qualified personnel.
Posted on Jul 15, 2009
My ge heavy duty large capacity washer stopped during wash and smelt burning rubber... Is it worth fixing?
certainly-- the burning rubber is probably a loose or broken drive belt underneath
however the ultimate decision can be made after a service person has inspected it and quoted on repairs and parts ( if still available)
Apr 14, 2015 | GE Washing Machines
Delta unisaw stops running
Probable overheating problem. Take it apart clean it and put it back together. Sawdust still can get into the machine and becomes an insulator which in this case keeps the heat in. Take caution cleaning around the electrical areas. I suggest using rubbing alcohol in combination with que-tips for electrical parts. If it is just overheating and there has been no lasting damage caused this should fix the problem. There probably has not been any lasting damage caused by this issue if you have never smelt anything burning but for extra reassurance when you open it look at the sawdust before cleaning for burnt marks.
Mar 25, 2014 | Delta Saws
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
When i pressed the power button, the notebook didn't turned on.
Assuming that the laptop either had the battery fully charged, or the power plug is supplying the power.
The issue may be the power button. I have had some break. It is very interesting how flimsy some of those buttons are attached.
If you can remove the top bezel that covers the power button you may get a better look.
The power can be actuated by a small button not much bigger than a pin.
Good luck
-Carlos:
Jan 06, 2010 | Dell Latitude D600 Notebook
I have a motormaster 1750 inverter hard wired in my semi truck, I had the inverter turned off, I replaced all 4 batteries started the truck smelt something burning and now the breaker on the inverter...
Recommend (1) open the inverter (with battery power disconnected) - and inspect incoming cable between the power switch and the battery cable entrance. Possible that a wire overheated and shorted on the input cable.
Next (2) if problem cannot be located, go to http://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter and replace it with at 2000 watt inverter for 130 bucks.
Dec 29, 2009 | Electronics - Others
Broken battery latch cover
no, is not practical to repair. you can do bigger mass what is now. only what you can do is secure cover with self-adhesive tape. if you not satisfied with this, go to service and pay repair.
Feb 09, 2009 | Nikon Coolpix L15 Digital Camera
Black Blob on bottom of Screen
Broken screen , replace it with new TV as the repair will cost at least 75% as much.
Dec 23, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Samsung sc-D363
I had the same problem. The batteries do not last. When the battery becomes weak it can not run the tape so it tells you to eject it.
Buy a new bigger battery. I bought a 160 for ~$30.
Jan 17, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Digital Blue iUbi Blue  Digital Media Player Logo
54 people viewed this question
Top Digital Blue Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digital Blue Audio Player and Recorder Expert? Answer questions, earn points and help others
