Question about Ricoh Office Equipment & Supplies
Ricoh ft 4415/18 blink auto image density indicator whats?
  • 2 more comments
  • bbuono645 Jul 15, 2009
    thanks for rapid answer, you speak of ID sensor near the drum? and what is P.M.
    thank sandmanmac
    thank sandmanmac
  • bbuono645 Jul 16, 2009
    sorry sandmanmac have you the page 12-44 of the servise manual of this macuine, it says about the blink indicator.
    thanks
    gino
    thanks
    gino
ID sensor error. needs new sensor, and.or full P.M
Posted on Jul 15, 2009
Testimonial: "also too later, i have cleaned the id sensor image the machine it's ok and never blink more. thanks"
Hi. I have a ricoh ft 4615. Heating is ok, gears moves as normal, each n every function is working but the print page is blank and displays U6. What might be the problem?
Try this:
Turn off the auto density
Go to manual density and adjust to the middle 50%
Try to run again and check your results
If none - you have to clean all the optics
Try again - if you don't get results there is a possible problem with the lamp/scanner system which usually requires someone making adjustments to one of the control boards.
Which brings you to contacting Ricoh for support - they are usually pretty good helping over the phone.
Ricoh's support and download link is below, if this doesn't work scroll to the bottom and click on contact us.
Support and Downloads
Best Wishes,
Joe
Aug 25, 2016 | Ricoh Office Equipment & Supplies
How to reset Ricoh mpc2030 color copier sc400error
You have to clean the Image density sensor and restart the machine, code shall go by itself.
Dec 18, 2015 | Ricoh Office Equipment & Supplies
We have an error code that just started on our beloved copier from Ricoh. It is 54 E, can you tell me if this is the end of the line for our copier or is there still life in the old bird?
time to get rid of it. i am highly skilled in the repair of this dinosaur. that is a fuser code and 9 out of ten times the fusing thermister has failed and is a pain to replace. many times the thermister has rubbed a scratch in the hot roller. you do not want to see the bill for that replacement.however a few seldom times the code 54 can be a fluke and can be cleared out thru the clear code procedure listed below. yes it is ridiculous to do but easy once you know how. REMEMBER IN STEP THREE YOU ENTER "97" AS THE DESIRED SP NUMBER. good luck
Access Procedure 2 - Using DPS101-2
1. Turn the main switch off.
2. Remove the BACK rear cover AND EXPOSE THE MAIN BOARD. LOCATE DIPSWITCH 101 ALSO CALLED DPS101 AND PUSH UP THE NUMBER 2 SLIDE OF THE 4 SLIDES and turning on DPS101-2, then turn on the main switch. "5" will blink in the Copy Counter.
3. Enter the desired SP mode number IN THIS CASE " 97 "by the numeral keys. SP mode
numbers are given in the Service Program Mode Table.
4. Press the Auto Image Density key to view the data. IN THIS CASE INPUT A "1" AND PRESS AUTO IMAGE DENSITY KEY TO CONFIRM AND ENTER THE "1"
5. To leave SP mode, turn off DPS101-2.
NOTE: To cancel an already entered SP mode, press the Auto Image
Density key.
Jun 14, 2011 | Ricoh FT3713 Copier
I replaced the toner...but i am not getting dark copies...how do i fix this?
Activate the forced toner supply and the auto proces control and auto image density level process.
Dec 03, 2009 | Ricoh Office Equipment & Supplies
I have one problem for copier konica 7175 when I make copies of a document that presents a stamp in blue or yellow it is invisible in my copy. thank you
Clean the optic parts componenets(mirrors,lens,lamp),the charge corona wire and unit amd change the value the auto image density or change the OPC drum.
Dec 02, 2009 | Ricoh FT5832 Copier
My richo ft4822 copier is now printing blank copies. Before this, image density was faint even if you set to maximum density.
Clean the optics and change the transfer/separartor corona wire.Verify the drum ground plate connection.
Nov 11, 2009 | Ricoh Office Equipment & Supplies
I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Aug 24, 2009 | Office Equipment & Supplies
Ft 4415 ricoh flahing the magnigication indicator display
That means the machine is due for preventive maintenence, or PM. There is an internal counter that keeps track of the number of copies made. At a preset count, this indicator flashes. Kind of like "it's time for an oil change"
Aug 24, 2009 | Ricoh Office Equipment & Supplies
179 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
