Question about Toshiba Satellite A135-S2386 Notebook
CHARGER - Toshiba Satellite A135-S2386 Notebook
  • 52 Answers
If you want charger means buy a universal adapter which costs around 750 rs and adjust the volt as your laptop volt and make use of it....is this cleared your problem?
Posted on Jul 15, 2009
Hello I need the 14 volt 1000ma barrel-end charger for the Kalee Fire Truck. 40029 I can't get it anywhere
One of these. Here you go
Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery ...
https://www.saretailinc.com > RideOn and Toys > Replacement Parts Best price for Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery Charger (Barrel End)
Amazon.com: Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys ...
https://www.amazon.com/Kalee-1000mA-Battery-Charger-Barrel/dp/B016V5Q1EG Amazon.com: Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys & Games.
Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma ...
www.bestscooterbuysstore.com/kalee-14-volt-battery-charger-2-prong-12-volt/ Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma Charger (Labeled 14v Charger) ... Kalee 12v 1000ma Charger (Labeled 14v Charger). This item usually ships ... Mini Motos 12 Volt Barrel-End Charger $31.99. Kalee 6v ...
Oct 23, 2017 | Cars & Trucks
Tip
Digital camera battery, camcorder battery and charger online store -...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 21, 2010 | Computers & Internet
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
''WARNING BAD CONTACT OF CHARGER'' shows. where is the problem? charger 100% ok.
Either your charger is not ok or your phone may have some problem.U should the charger which is designed for your phone.U may try wetting the pin of charger with a little much of saliva and then dry it and then connect the charger again.If it again shows bad contact of charger reconnect and if the problem persists then the phone may have a faultu jack.To check your jack connect phone to other charger if it again shows bad contact of charger then this is it your phone has got some problem
Jan 10, 2012 | Cell Phones
I lost my charger, is there any store here in manila that sells charger only
You can use motorola V3 charger as an alternative charger,htc charger is difficult to find and expensive as well,i'm also using the same phone as yours and i never had a problem using motorola charger,but if you really want HTC charger,you can go to CITY PLAZA at Quiapo,manila,but not sure of getting original charger,only class A is available,or even go to any mall nearest you,might spot original HTC charger as well.
Aug 06, 2011 | HTC G1
Charger problem how to identify
Hi, to identify charger. You will need to test another charger on the cell phone and test that same charger on another phone to confirm if the charger is working.
Also after testing for the charger and and if the charger works, that means the charging port of the phone where the charger is been inserted is damaged.
It will need to be fixed.contact you local repair person for help.
Take care.
May 22, 2011 | Cell Phones
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
China mobile,warning,bad contact charger when connected to the charger.
i have foreme f8 phone when i m charging it then it will say after some time bad content charger solve it
May 27, 2010 | Cell Phones
Toshiba Satellite A135-S2386 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
