Question about Canon Office Equipment & Supplies
Error 354 I have IR-3300, and I had to change the card to verify controller PCB mistake in another copier (E733) and return the card to its place of each copier, but now mark the 354 error. as we can solve this ??
    Problem Solver:
  • 5 Answers
Error e354 code appear when you replace PCB controller board.
Please note. Before replace your old PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Posted on May 11, 2013
    Sniper:
  • 118 Answers
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Posted on Jul 15, 2009
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
Canon ir 6000 ranning copy machine hang 2minet before e733
Dear
1) Turn off and then on the main power switch. Is the problem corrected?
YES: Check the operation once again; if normal, end the work.
Check Connectors, DC controller PCB
2) Is the connection of the connector (J1015) on the main controller
PCB and the connector (J122) on the DC controller PCB normal?
Further, is the cable between these connectors normal?
NO: Correct the connectors/cable.
YES: Replace the DC controller PCB.
Thanks.
Feb 07, 2015 | Canon imageRUNNER 6000 Copier
How to sol error coad E000733-0001
Error code E000733-0001 on Canon IR2200
E733-0001 means a fault is detected by the main controller PCB in the communication between the DC controller PCB and the main controller PCB.
Main cause: The connector has poor connection. The DC controller PCB is faulty.
Solution:
Verify the connection between the connector J1015 on the main controller PCB and the conductor J316 on the DC controlled PCB is normal.
Correct the connection if necessary.
The connection is correct: Replace the DC controller PCB.
Dec 17, 2014 | Office Equipment & Supplies
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
My canon ir 3200 have a code error E 732 I dont now what to do
getfile.asp?rid=1258 March 3, 2009 getfile.asp?rid=3215 Product : imageRUNNER C3200 / 2620 / 3220 Title : E732 and E733 are Displayed, when Copying off the Glass or when using the DADF
Error :
Error codes of E732 and E733 are displayed, when copying off the glass or when using the DADF. The Control Panel would go blank and the processing data light would continue to blink. After a few minutes in this state; the copier was rebooted and the codes would resolve themselves, but would eventually return.
Workaround :
First, try reseating all the connectors to the Reader Controller, Interface PCB, and DDI-S PCB. Next,
check for proper voltage to all three boards.
In this case, a defective DC Fuse PCB caused the error codes. An intermittent loss of voltage to the Reader Unit caused the machine to code out.
Note:
The part number for the DC Fuse PCB is FG3-3020-020.
Canon USA, Inc. Systems & Technical Support Division
Nov 12, 2010 | Canon imageRUNNER C3200 Copier
Error code 354-0002 ir7200 serial number pcb
when you changed the main controller for the copier did you use the counter board that was on the old main controller or did you put the counter board from the old one on the new one.... if you don't use the old counter board with the new main controller then that problem will occure
May 19, 2010 | Canon imageRUNNER 7200 Copier
Error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
Jan 23, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR-3300, error 354
E354
Jul 14, 2009 | Canon Office Equipment & Supplies
E000733-0001 the err means I have the same problem, the same error code: E000733-0001 on my Canon IR3100CN. I cannot pass to service mode...After I switch off & on, the display shows me the same...
E733-0001 Error Code
E733 and machine locks up with progress bar at 98% on boot up?
I would refer this error to a qualified service Tech.
Deals with replacing DC controller, Main Controller and Boot Rom as a set. Also, mention of replacing the Switching Regulator PCB Assembly if the previous failed to resolve.
May 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
477 people viewed this question
old marine
old marine
