Question about Zenith B27A11Z 27" TV
How do we manually change channels? - Zenith B27A11Z 27" TV
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Channel lock is stuck on
May 28, 2011 | Televison & Video
How do i switch the channels on the router?
Hi susanwhitbou !
To change the wireless channel, type in your browser address bar : 192.168.0.1 If you haven't changed them, your username and password should be admin and blank. Next, when you see your router's setup page, press on Manual Configurations, and then on Wireless Setup. Now, in order to change the channel manually, untick the box that says Auto Channel Scan. After you'll do that, you will be able to change the channel by pressing on the drop down box that says Auto Channel Scan.
Hope that helps, omerk
Feb 22, 2011 | D-Link DIR-615 Wireless Router
Cannot change the channels !!!
press menu button....change autotune to manual channel set ...then just add the channels you want
Nov 28, 2009 | JVC AV-27D305 27" TV
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Sub-Channels
Here is a link to a list of older TalkAbout user manuals. Use the pulldown menu to look at various models. In general, most of them program similarly by using the menu button to select the feature and the PTT button to lock in the change. http://www.giantintl.com/motorolafrsold.htm
May 26, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
CAN'T CHANGE CHANNEL MANUALLY AND REMOTE DOESN'T WORK
Hi again,
Many thanks for the wonderful review and the rating.
Good luck and kind regards.
Thank you again for using FixYa.
Nov 07, 2008 | Sharp LC13B6US 13 in. EDTV-Ready LCD...
Can not change TV channel on DVD Recorder.
some dvd/vhs tuners do have this locked issue and since poor qc or qa on the manuf. part , they think since items are low cost anyways buy another one.
Mar 27, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Zenith B27A11Z 27" TV Logo
42 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
