Question about Ovens
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
How can you remove burnt plastic from electric hob oven
from the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
Apr 16, 2017 | Ovens
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Smeg oven does not turn on - the light and the fan work but
Is the hob seperate from the oven? if it is then I suspect the problem is witb the oven, you need to check the supply to the oven to make sure you have got voltage, if you have then the prob is within the oven, and this could be one of several things
Some single ovens are sometimes plugged into a normal socket, in which case you need to check the fuse in the plug.
Hope this helps.
Plz leave feed back.
Ta.
Dec 09, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Hotpoint Double Oven ceramic hob
suspect more than one problem. half grill not working may be due to half the element gone open circuit. the other problems could be due to an installation fault. many ovens have links in the connection box which have to be tightened down. this is often overlooked. look at the connection box or terminal strip to check. there is often a diagram of hoiw it should be done adjacent.
Jun 02, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
764 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
