Question about Video Cameras
There is a lead from the battery charger that goes to the camcorder so you don't have to use batteries. I have lost the lead can anyone help ? Thanks
    Sergeant:
  • 285 Answers
Try calling the mfgr, or try ebay or google
Posted on Jul 15, 2009
Hi, my Gsxr k1 dead put key in and on nothing take key out rec counter needle go up and down sometimes if u put kill switch off and key on dash goes on but not petrol pump. Checked and clean all electric...
Hi, Please check all fuses if all OK I would check the Battery. A dying battery causes all manner of problems. To remove a battery please undo negative lead first. When you refit a battery please connect positive lead first. Check the battery for life use a volt meter your battery should show at least 12.5 volts if OK try charging it for a while on a dedicated motorcycle charger. Please never use car, boost chargers or jump start from another vehicle. I hope this helps good luck.
Feb 12, 2015 | Goes Motorcycles
No power from batteries and the camcorder will
I have the same problem. The battery is charged, but the camcorder will only work while plugged in. It worked for a while on the 1st day, Christmas, then it would only turn on while plugged into the charger and would stay on after charger was disconnected. Today it will only stay on if plugged into charger.
Dec 26, 2009 | JVC GZ-MG330 HDD Camcorder
Lost my charger trying to figure out how charge?
You normally charge the battery directly with the adapter that came with the camera.
To order a spare battery and charger go to
http://www.eastcoastphoto.com/nav/bfinder.asp?category=Camcorders&manufacid=13&itemno=DCR-DVD610&trng=AW&gclid=CLLIxqXUn5wCFRlcagodrgjXeA
You may be able to order the lost direct charger from them also.
Please rate this solution. Thanks.
Aug 13, 2009 | Sony DCR-DVD610 DVD Camcorder
Need part
I had one of those and it was so out dated can't get parts. My battery burnt out and could not find a replacement.
Mar 14, 2017 | RCA CC6151 Camcorder
My jvc camcorder GZ-MG37U will not charge
Camcorder has charging circuit but it could go defective. The repair would be costly so in this situation, you can purchase stand-along battery charger for around $20 and charge the batteries independently. Make sure all the contacts are cleaned and camcorder is working with direct ac adapter. Good luck -James. for furnter assistance by email, go to www.camerarepairjapan.com
Feb 11, 2009 | Canon XL2 Mini DV Digital Camcorder
Instruction manual
Your specific manual is here.
You can find Sanyo UK owner's manuals here
Sep 13, 2008 | Microwave Ovens
Jazz DV169 issue
umm i have jazz camera and i didnt have a charger **** i bout a motorola house cahrger and it charged my camera.
Aug 01, 2008 | Jazz DV169 Camcorder
Battery does not charge
If is is only months old, contact the seller for warranty diagnostics and repair. It can only be the charger, the lead or the batteries.
Mar 04, 2018 | JVC GR-AXM18US Camcorder
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Apr 13, 2006 | Samsung VP-W75 Camcorder
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
