Question about LG 24 in. LDF7810 Built-in Dishwasher
LG DF7810 small leak - have had a repairman twice and they can't seem to find the problem - replaced the seal and it still leaks
  • Barbara Curry
    Barbara Curry Jul 15, 2009
    it is a stainless tube - how can it have a crack
  • 4 Answers
I don't believe your tub is cracked. I have the same dishwasher and the seal was my problem. Not that the seal was bad, it was that the seal and motor assembly weren't sitting snuggly in the tub hole. It appears that the tub hole to which the motor assembly sit in is a little to big. I tried the new seal, with the same results, still leaks. So I ordered food grade silicon from EMI Supply. I applied the silicon to the inside of the seal (which attaches to the motor assembly) and the outside of the seal (which sits against the tub). Problem solved. LG just need to increase the size of the seal a little and it would solve the problem, but for now, we have silicon.
Posted on Mar 23, 2010
  • 297 Answers
The tub inside has a crack,it happens time to time.you must replace unit.
Posted on Jul 15, 2009
Tank leaking at meter
The tank could be leaking itself
Dec 05, 2013 | Plumbing
Dishwasher Leaks
Find a new repair person
Apr 07, 2017 | LG LDF7932ST Dishwasher
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
When i run the washer there is a small water leak coming from the front of the door.
sounds like u have your front door seal leaking make sure theres not any trash in the seal or around the door if not u might have to replace the seal
Feb 26, 2010 | LG WM-2277HW Front Load Washer
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
Leaking power stering pump seal--how to fix?
I suggest replacing the pump...after you have bought a seal kit and tools to remove the pressed on pully you will have spent twice the money....most auto stores will replace the pulley for you at a small charge
Jun 04, 2009 | 1993 Lincoln Town Car
Huge oil leak
You have replaced it twice, perhaps the fly wheel is cutting it or inside the part that connects to the crankcase is an "O"Ring or you have to inspect the fly wheel look for cracks, inspect the seal that You all ready removed
Jan 22, 2009 | 1995 Nissan Quest
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dishwashers Logo
184 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
