Question about Ariston Technologies L63 Free-Standing Dishwasher
The drain pump is not working well
I think the pump is clogged, i need to take it out and clean it
  • 51 Answers
I would try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Posted on Jul 15, 2009
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: water does not drain from tub
If this is a Whirlpool top loader as you have this listed under, you need to check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If the lid switch checks good, you can still inspect the drain pump if you like. However, there are no electrical connections on this pump and it only has one moving part - the impeller. They do not commonly clog. The steps for removing the washer casing in the link I provided will give you access to the drain pump. It is located directly below the wash tub on the front. If the tub is full of water, an easy way of draining it is to use a wet/dry shop vac and pull a vacuum on the drain hose. If the water drains freely with no restrictions (if restricted the drain line will collapse from the vacuum), the pump isn't clogged. If you don't own a shop vac, simple gravity will also do the trick by placing the drain line on the floor. However, I wouldn't recommend this unless the washer is in a garage or basement where the water can drain somewhere. Once the tub is drained, you can remove the two drain hoses and check inside the pump for obstructions.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete the repair if replacing the lid switch.
Posted on Sep 11, 2009
Dishwasher filled and does not drain. I think the dial is faulty; however, how do I drain the water.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
My maytag dishwasher won't drain. It is not clogged. It just won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Jan 31, 2011 | Maytag 24 in. DWU9202 Built-in Dishwasher
Water won't drain from the tub, think the hose may be clogged. Is there any way to clean the hose without completely dismantling the machine? It does spin but the water won't completely drain out. We...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Frigidaire FWS833A Top Load Washer
Dishwasher siemens is not draining water.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Siemens WFXD8400UC Front Load Washer
THE WATER WILL NOT DRAIN OUT
Kevin
Dec 14, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water is not draining out
Kevin
Dec 13, 2010 | GE Nautilus 24" Built-in Dishwasher
Water is not draining from the tub at all
Kevin
Dec 13, 2010 | Frigidaire Dishwashers
Will not drain water
Kevin
Dec 13, 2010 | Amana 24 in. ADB2200AW Built-In Dishwasher
Dishwasher will not drain.
Washer not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Washer will not drain totally when in final rinse mode.
Kevin
Dec 09, 2010 | Maytag Dishwashers
Ariston Technologies L63 Free-Standing Dishwasher Logo
422 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
