How to replace a print head on a T2265 sprint pro
    Scholar:
  • 71 Answers
Tally Genicom T 2265 Printer print head. The following information regarding Print Head is taken from Website. Please go through carefully. Print heads are very sensitive from the type of ribbons you use. These textile tapes, used as consumable in dot matrix printers are made by special technologies. They are impregnated with ink and special oils, which lubricate the print head wires during printing. While print head works, the quantity of ink and lubricant in ribbon exhausts, and the quality of printed matter gradually declines. When this quantity goes down below certain limits the ribbon begins wear to threads. These fine textile fibers mix with cellulose filaments from the paper and form a dark gray dust. This is a sure sign that the ribbon is dangerously worn and must be changed with a new one. Otherwise you will soon need a print head repair service. Still not satisfied about those points, please get in touch with local authorized printer service engineer to set right the issue. Have a Nice Day The same problems you may have with "old" ribbons, because after time the lubricants and inks get dry. The usage of "worn" or "dry" ribbon leads to difficult movement of the printhead's wires, its quick wear or crush. If you wish to use your printhead for a long time without any problems, you must use a quality ribbons with an original guarantee. Never use re-inked old ribbons. This surely guides you to print head repair or to buy a new one. It is a good idea to read the User's Guide for your printer, if you have not already done so. If you don't succeed in finding it, then carefully look at your printer and try to find the lever for printhead positioning, it controls the printhead gap. You must adjust manually this gap in correspondence with the number of printed copies.
Posted on Jul 17, 2009
I have the Epson Stylus Pro 3880. Up till a few weeks ago all was well, the today, it decided not to print out the black areas of my shots. I've check the inks, the heads all is well. HELP
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 02, 2012 | Epson Stylus Pro 3880 InkJet Plotter...
Block/yellow printerhead is not good
My HP L7590 print head B/Y has a problem. I tried unpluggging it, replaced the print head and cleaning it. It still has a problem
Sep 14, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Epson stylus pro 4000 i have a clogged nozzle cant move it other 7 are fine
Inkjet printers needto be used frequently to prevent ink drying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 03, 2011 | Epson Stylus Pro 4000 InkJet Printer
Pdf printing is not properly impression on the line priter tally t6090 ,plz help harish
Hi, maybe this TechNote will help you:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=296%3Apoor-print-quality-when-printing-adobe-acrobat-pdf-files-&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 12, 2010 | Tally Line Matrix T6090 Printer
T2265 check ribbon +0000 35---- 114002+ 32 32 4049
This error is indicating a problem with print head movement.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
That the he printer ribbon is not jammed and is located correctly in the printer,
Check to ensure there is no paper jam of loose paper which may prevent print head movement
Check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the print head.
You may then need to check the following for faults;
Ribbon Driver
Carriage Motor
Carriage Belt
Timing Strip
Logic Board
Interconnect Board.
Jan 07, 2010 | TallyGenicom Office Equipment & Supplies
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Model T2280. How can I correct AGA error?
This is normally caused by a bag AGA sensor.
TALLYGEN 447540 AGA ASSY T2265 New
Link lists a T2265, but the sensor is the same.
Jun 08, 2009 | Tally Office Equipment & Supplies
I have a tally t2265. when i switch it on it comes up with "hardware error". Please help Don
9 out of 10 times this error is caused by the print head assembly binding up on the platen (the metal bar that the print head moves back and forth on). Remove the ribbon and paper from the printer. Wrap a thin cloth or Kimwipe around the platen and spay some WD-40 on the cloth. Work the cloth back and forth on the platen to clean it. Then with the platen still damp with WD-40 work the print head assembly from side to side, this will clean out the inside of the print head assembly. Clean the platen one more time.
I have seen this problem caused by two other things, a defective ribbon casette or worn out drive gears.
Dec 01, 2008 | TallyGenicom (048959) for T2265, T2280,...
Please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Aug 20, 2008 | Tally Dot Matrix T2265C Printer
Printhead hot error on tally t2265 but all pins fire ok, just stops and gives error, printhead is cool to touch, after a few minutes it prints a line or two again. it does this immediately, not after a...
The problem is with the main board when it gets print head hot immediately. The power supply is still functional, but something on the main pcb portion causes it to give an immediate "Print Head Hot" alarm
Jul 22, 2008 | Office Equipment & Supplies
257 people viewed this question
jasbo
jasbo
