Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Where do I find the model number of my GE Profile gas range?
The broiler and top burners work, but not the oven. The range was already in the apt. when I bought
    President:
  • GE Master
  • 1,922 Answers
On back of appliance near top behind control panel but should be on outside of rear cover
Posted on Jul 28, 2009
Prpane back to ng. Changed top burner apertures. Is there anything else I should do for the gas supply
The range burner orfices need to be changed to the natural gas ones. I am assuming when you say "apertures" you are talking about the burner orfices. If so then you have already changed the range burner orfices. There is also a orfice that usually needs to be replaced for the oven burner and top broiler burner (if you have a top broiler). And then there is usally a pressure adjustment required on the appliance gas regulator. This is usually adjusted by simply removing the regulator cap and turning over the spring tension plug inside and then re-installing the plug and cap.
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Stove, stove top works but the oven will not heat up.
You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
Mar 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Oct 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
Aug 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
479 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
