Question about Olympus FE-210 Digital Camera
The lens opens and makes a ticking sound but light stay orange
Is there any way to fix this? Lens open but LCD never lights up or allows you to take a picture. Light on back never goes green. LCD is fine causes I can view pictures. Camera wasnt dropped worked one night and the next morning it did this. Tried fresh batteriaes as well. Just wont go completly into picture mode.
  • 744 Answers
Hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Posted on Jul 15, 2009
  • Cris Marte Mar 29, 2011
    Now, how do I realign the fallen gear or actuator? Although It was suggested on another page to buy a new camera than to spend a forty dollar fee for repair, I will take the risk on fixing it myself. Thus, this question. I hope somebody would give me a guide...
Doesn't start, clicking sound in lens assembly, any solutions?
  • try connecting the unit directly to the adapter or power source . batteries might also be poor and unable to open the lens. if it still don't work then there might be a mechanical problem with the lens have it checked at the nearest service center
Aug 23, 2014 | Panasonic SDR-H85K Camcorder - 80GB - 78 x...
Camera keeps opening and closing, orange light comes on
Wow, Not even the manual knows this error. Must be serious. It can mean two things in my mind. The lens is obstructed some how. Inside or outside. Or the battery is not ok. If you can't see anything on the lens barrel outside, please try to charge the battery. The camera will shut down without warning, when the power is low. Be aware the camera won't work as you expect, when a USB cable is attached. Actually you are not allowed to connect the charger, when the camera is still switched on. Look how the charger reacts. See if the battery is charged as before, because if the signal battery full does not appear it could be you have to buy a new battery.
Success.
Jan 13, 2014 | Olympus Stylus 700 / 700 Digital Camera
My Olympus fe-320 camera is not opening. The lens will not open up at the front. It makes a strange sound, and flashes the orange light for a little while, then switches itself off. What do I do??
It looks like some dirt or dust got inside the lens mechanism. Try to use a vacuum cleaner to get the dirt out of between the rings. And also check the baterry status...if weak the simptomps are the same (but no such noise as you described)
Aug 07, 2011 | Cameras
Lens is stuck with the barrel out. I hit power button and the light only turns orange then shuts off. If I hit playback button...says busy and shuts off.
I can't tell from your description what type of camera you are using, but it sounds like the battery is dead or dying.
It takes a lot of batter juice to open and shut the lens, and to power the LCD screen to view photos.
I hope this helps!
Mar 06, 2011 | Cameras
Canon sd300 cant see pictures taken
This may sound silly, but did you check the shutter on the end of the lens when the camera is on to make sure that the shutter is open? Sometimes some dirt or sand can get into the lens barrel and make the shutter get stuck in the closed position. If this happens, gently open the shutter with a a toothpick or something (NOT your finger because of the oils and NOT something that will scratch the lens).
If the shutter is open and the pictures turn out black both on the camera's LCD and on the computer once you download them, then I'm guessing something happened to your CCD, which is the tiny electronic chip that records the light coming through the lens. Either something inside the camera has fallen in front of the CCD and is blocking the light (unlikely) or the CCD chip has died. If that's the case, I hate to say it but buying a new camera would be more cost effective (and probably cheaper) than getting it fixed.
Apr 10, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Dropped camera-lens stays open
The only way to fix a lens error is to send into casio and have it fixed. Call them at 800-706-2534 option 2 and tell them you have a lens error. They will tell u how to go about sending it in for repair.
Nov 25, 2007 | Casio Exilim EX-S600 Digital Camera
Camera lens will open then close, plus both orange and yellow lights both flashing all the time
In addition to the one year World Wide Warranty,
issued by Olympus Corporation in Japan, the European warranty, issued by Olympus Imaging Europa GmbH, is
valid for two years from the date of purchase, if purchased after 1st April 2004
Oct 10, 2007 | Olympus FE-140 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Olympus FE-210 Digital Camera Logo
321 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
