Dell D610, spontaneous power down. Rebooted OK on battery. PC-12 (65W-AC) brick LED blinks green once after plugging it in, but does not charge notebook. Is it the notebook or the power adapter?
  • liem638 Jul 15, 2009
    When notebook is powered off, the charge indicator on the notebook does not illuminate. When powered on, the battery indicator blinks because its almost out of charge.
  • 24 Answers
How you can test that is by completely removing the battery and then see how it boots up. If it wont boot then i would suspect the system board.
Posted on Jul 15, 2009
I have d610 battery indicator flashes orange and green alternately i used ac adaptor to have power , once i plug out it turns off. i try a new battery do same thing? pls help
It may be that the power brick your using is damaged. You may just need a new power cord. Sometimes power cords can be damaged quite easily.
Mar 01, 2011 | Dell Latitude D610 Notebook
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Dell Latitude D610 Notebook
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
Battery light flashes 4 times red then once green. Charger is functioning and the battery is at 100% charge. In power options it shows another position for battery no.2 however there isnt one. The laptop...
Jason
Here is a link on the LED issue
http://www.fixya.com/support/r3696096-dell_portable_battery_led_flashes_orange
The battery is usable, but will slowly decline.
The system has the option of a 2nd battery in the media bay (In place of the optical drive) but since you don't have one installed, it just shows the 2nd battery as an option
May 05, 2010 | Dell Latitude D610 Notebook
Power light blink orange 4 times, 1 green?
My guess is that the battery is worn-out -- no longer accepting a charge, nor holding a charge. Replace the battery, or find a specialty business that "refurbishes" batteries (by opening the case, replacing the cells, and re-sealing the case).
Mar 04, 2010 | Dell Inspiron 6400 Notebook
Dell d610 wont turn on ac adapter light is green
There is a small IC that Dell solders into their power supply as well as their batteries. When this parts fails you will have the type of problem you are having now. If you do a search on the web you will find a large number o sites that discuss this. Unfortunately there is no fix other than replacing your power supply. I had to do the same thing myself for the Dell laptop I use.
Nov 02, 2009 | Dell Latitude D610 Notebook
Dell Latitute D610 is no longer working under AC Power
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Oct 08, 2009 | Dell Latitude D610 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
