Question about Kenmore Refrigerators
Kenmore side/side refrig
My kenmore side/side refrigerater(Model# 253.55693406 with Serial# LA 50121889) is not freezing things and making ice on occasion. I have read the manual and tried to trouble shoot and come up with nothing. I have just replaced the filter cartridge at the end of June. Our house was built in 2002. Inside the fridge is says Manufactured 01-05. Any help would be great!!
Thanks!!
Kevin
    Top Expert:
  • Kenmore Master
  • 36,564 Answers
Your Kenmore may be suffering from old age.
Posted on Jul 25, 2017
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
fridgetech
  • 473 Answers
SOURCE: My kenmore refrigerator side by side
Sounds like it has a defrost problem.  Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction.  Also, give me the entire model # from the sticker inside fridge.
Posted on Oct 18, 2007
SOURCE: Kenmore Coldspot Side by Side Model 51559101
I have a Kennmore side by side model # 522521 it all of a sudden the freezer part stopped freezing, the motor is still running. The Refrigerator part stopped cooling just after that.
Posted on Oct 19, 2008
woodchuck789
  • 4070 Answers
SOURCE: Kenmore refrigerator (model 106.78187891) leaking inside
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 14, 2009
mgprice
  • 744 Answers
SOURCE: I have kenmore refrigerator model- 253 67172504. water inside
Hi. The problem here is going to be with the defrost drain. Follow tthis link to my tips for full details on fixing this problem. Mike
http://www.fixya.com/support/r3557045-how_to_clear_a_blockage_in_the_defrost_d
Posted on Dec 27, 2009
Does kenmore refrigerater model 596.57542791 have a water filter ?
In a search of the parts breakdown for your model# their is NO listing for a filter. If it did have one it would be in the refrig, compartment on the right side ceiling above the top most rack/shelf
Aug 13, 2011 | Kenmore Refrigerators
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
I have a Kenmore refrig./ model# 363.9741714
The problem is actually not the ice maker itself. The problem is the electric solenoid valve in the rear bottom of refrigerator. If you follow the water line on the back of the unit down to the bottom and replace the valve that it is connected to then your problem will be solved. Hope this helps. Good luck cj2176.
Jul 25, 2009 | Kenmore Refrigerators
Fridge: not making ice, no water in ice maker
look to the water inlet valve behind refrig sound like you got a frozen line, or a bad solenoid
Feb 19, 2008 | Refrigerators
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Sep 10, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
